JRSC water hose line ques????? help
ok on step 116 of the JRSC instructions i did the step involving puting the hose from the manifold to underneith the throttle body, but then i have a hose with a metal copper metal pipe on the end from which taht hose use to be connected to a line that went to the throttle body but the other hose has replaced it.i dont know where it goes and if i follow it back it goes do a little fitting on top of the upper radiator hose that goes into the head. Where does this hose with the metal copper end connect to ???? i need help
PSI Racing
10
Jan 27, 2020 04:28 PM
2000vsm
Aug 25, 2003 07:14 PM
