any info on "homemade" Greddy remote switch?
Old Dec 9, 2002 | 05:43 PM
JAMinCiViC's Avatar
Default any info on "homemade" Greddy remote switch?
I searched and found something about a head phone jack and a switch??
Do i just find a jack that fits the rear of the profec B and hook up a 12v switch to it??
Old Dec 9, 2002 | 06:24 PM
niedejb's Avatar
Default Re: any info on "homemade" Greddy remote switch? (JAMinCiViC)
I did a little write up on it.
Let me know if you have specific questions.
http://home.insightbb.com/~niedejb/switch2.html
Old Dec 10, 2002 | 09:03 AM
JAMinCiViC's Avatar
Default Re: any info on "homemade" Greddy remote switch? (niedejb)
Thanks so much
Old Dec 10, 2002 | 09:21 AM
Vanilla Ic3's Avatar
That'd be sweet to do on steering wheel mounted cruise control buttons. I never use mine. Or if you have radio controls on your wheel you could use those.
Old Dec 10, 2002 | 09:25 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: any info on "homemade" Greddy remote switch? (Vanilla Ic3)
would it be possible to use only one of the horn buttons for this, while keeping the other horn button in use?
Old Dec 10, 2002 | 09:26 AM
Gmedalion's Avatar
Default Re: any info on "homemade" Greddy remote switch? (Boosted97Lude)
Nope, they are hooked together.
Old Dec 10, 2002 | 09:27 AM
blackteg's Avatar
I have a question about it. Will it handle the 12 volts or do I need to step it down in one way or another? Any chance you have a pic of what the wiring should look like? Or what goes to where? I'm not that good with electrical if you can't tell.
Old Dec 10, 2002 | 12:02 PM
Finest's Avatar
Default Re: any info on "homemade" Greddy remote switch? (blackteg)
Since the two horn buttons are hooked up together, can't you just isolate one button and have the other one activate the switch?
How are the two buttons combined?
Old Dec 10, 2002 | 01:02 PM
niedejb's Avatar
Default Re: any info on "homemade" Greddy remote switch? (Prelude_RCR)
The buttons are in series in the wheel itself. No you cant isolate them.
To answer the above question....yes it can take the twelve volts.
Old Dec 10, 2002 | 01:32 PM
falcongsr's Avatar
What is this crap?
if the horn switches are in series, then you'd have to hit them BOTH to get the horn to honk.
Old Dec 10, 2002 | 01:37 PM
niedejb's Avatar
Default Re: any info on "homemade" Greddy remote switch? (falc0n)
Oops...meant parallel
Old Dec 10, 2002 | 01:41 PM
Finest's Avatar
So parallel huh?
Can't you just keep one side wired to the horn, and have the other one run to the switching relay? I'll have to check this weekend if it works... hehhe
Old Dec 10, 2002 | 01:43 PM
falcongsr's Avatar
What is this crap?
i'd rather just have a switch under the dash somewhere
Old Dec 10, 2002 | 01:47 PM
niedejb's Avatar
That works too. Although a pushbutton is really what you want. It latches till it gets the next 12v signal.
I just thought the horn button would be novel.
bsmith100
Audio / Security / Video
Jul 23, 2010 09:30 AM
KnightX
Feb 6, 2007 04:19 AM
white_98_gsr
May 29, 2005 06:45 PM
civicx98
Dec 21, 2004 05:34 PM
