Is 10.5:1 compression too high
I'm running JE SRP pistons and want to go turbo. Some people tell me I need to swap out my pistons for lower compression ones like 9:1. Others tell me I can use these pistons, just don't boost more than 10 lbs.
I read before that it's all relative - lower compression pistons handle more boost and higher, less. In fact, it's better to start out with higher compression and use less boost than to make the same power with lower compression and higher boost.
What should I do?
What should I do?
get you some 700cc injectors, Fuel management system, Spend some money on someone WHO know the system and KNOWS what they are doing. you'll be fine with 10.5:1. Im doing the samething with my setup.
Remember its your setup dont let someone tell you different.
RTst92
Mar 5, 2006 01:56 PM
