High Idle on ls/vtec
Old Dec 9, 2002 | 04:41 PM
Chuji's Avatar
Default High Idle on ls/vtec
Im trying to start my new ls/vtec motor for the first time (91 ls block/00 si' head in a 96 integra). Using a type-r manifold and factory internals and I still have my stock non-vtec computer installed. The motor starts but immediatly revs to around 3,000 rmps and stays there. Im only throwing code #6 (Engine Coolant Temperature), and that connector clip got messed up. My throttle plate is closed. my TPS Sensor reads .45v when closed. IACV is connected correctly and showing no codes. FITV is sucking air through TB but im not sure how to check if its working fine. I cant find any vacuum leaks. Im using stock 00 Si spark plugs for right now and i havent set ignition timing yet. This is my first motor build and swap and its possible that I connected something wrong but im pretty positive everything is correct. Anyone have any ideas?
Old Dec 9, 2002 | 05:47 PM
Jeff C's Avatar
Default Re: High Idle on ls/vtec (Chuji)
Are there two ports inside the throttlebody just outside throttle plate?
I had a similar problem and it was that my fast idle was wide open. I just disconnected it and solved my problem.
Old Dec 9, 2002 | 08:11 PM
slyph777's Avatar
You said the coolant temp sensor was messed up ... doesn't this regulate the "fast idle" startup for warming up the engine? Or am I just talking out of my ***, since I don't really know ...
Old Dec 14, 2002 | 01:46 PM
Chuji's Avatar
Default Re: High Idle on ls/vtec (slyph777)
im still havin the same problem, anyone else have any ideas for me to try?
Old Dec 14, 2002 | 03:53 PM
AVATAR's Avatar
Check what the voltage readings are on the CTS unless you have corrected the code. CTS is a very integral sensor to the motors well being.
dark_reverie
Aug 15, 2014 12:39 PM
Tatakai
12
Apr 2, 2007 05:45 AM
vtecda
Aug 15, 2005 07:41 AM
luda98
Oct 14, 2004 07:05 PM
sk8phaze
Aug 16, 2002 10:45 AM
