b18A1 built 92 LS motor
Old Dec 9, 2002 | 03:44 PM
synergy004's Avatar
Default b18A1 built 92 LS motor
head:
port flow machined: port and polished job
ferrea valves
web retainers
web dual valve springs
new valve seals,
new web bronze guides
stock cams, stock cam gears
b20 valve cover
port matched intake manifold
bored butterflied and port matched TB
New timing belt
block:
Eagle rods
Arp Rod bolts
Je Pro piston 9.0:1 c/r
Je pro Rings
STR block guard
New thrust washer
New main seal
New rod bearings
New Main bearings
New oil pan gasket
b20 oil pump new
new Water pump
New oil control jet
new OEM head gasket
Perma oil filter relocator kit with filter already attached
b/m oil cooler
micropolished crank blue printed and balanced
Machining of block done by local reputable shop
short block has an accurate mileage of 1237 miles on it only. Drove on it to break it in. Took it out since i got another motor prepped, now moving on to new project so everything has to go. Never raced on drag. Driven very sainly
pics are available upon request.
asking 2300.00 obo buyer pays shipping. will seperate if both head and block can be sold around same time.
thanks
gil
email me or PM me
[Modified by synergy004, 4:55 PM 12/9/2002]
Old Dec 9, 2002 | 04:14 PM
synergy004's Avatar
Default Re: b18A1 built 92 LS motor (synergy004)
ttt
Old Dec 9, 2002 | 05:48 PM
synergy004's Avatar
bump
Old Dec 9, 2002 | 06:46 PM
synergy004's Avatar
lowered to 2100.00 or 2300.00 shipped
Old Dec 9, 2002 | 10:56 PM
synergy004's Avatar
i finally researched a lil more and i am lowering it to 2000.00 firm
ttt
Old Dec 9, 2002 | 11:57 PM
boostwhipped's Avatar
seems like a good deal
very similar to what i've got going right now
no sleaves, huh?
Old Dec 10, 2002 | 02:01 PM
synergy004's Avatar
Default Re: b18A1 built 92 LS motor (boostwhipped)
stock sleeves.
ttt
[Modified by synergy004, 9:47 PM 12/10/2002]
Old Dec 11, 2002 | 11:53 AM
synergy004's Avatar
can sell as whole or head and bottom end seperate
Old Dec 11, 2002 | 05:57 PM
synergy004's Avatar
still for sale...
Old Dec 11, 2002 | 06:14 PM
avividmemory's Avatar
bump for gil, hes a good guy good to deal with
Old Dec 12, 2002 | 10:19 AM
synergy004's Avatar
Default Re: b18A1 built 92 LS motor (SpoolinLS)
thanks bro.
Old Dec 12, 2002 | 08:59 PM
synergy004's Avatar
ttt once again, this thred moves fawkin fast
Old Dec 13, 2002 | 04:05 PM
synergy004's Avatar
ttt
Old Dec 18, 2002 | 12:55 AM
synergy004's Avatar
ttt again
Old Dec 18, 2002 | 01:24 AM
pissedoffsol's Avatar
25 Year Member
will you part out the oil cooler/relocation set up?
If so- whats the specs on these... pics?
Old Dec 18, 2002 | 01:41 AM
H22EK's Avatar
Default Re: b18A1 built 92 LS motor (delvtecsol)
wanna trade for jdm h22 with brand new mount kit and clutch, only 18,000klm on swap , very clean!
pm or e-mail is key
[Modified by H22EK, 2:42 AM 12/18/2002]
raytownracer
Sep 23, 2012 07:08 AM
viper_linx
Southern California
Nov 20, 2009 02:23 PM
Novtec4u
30
Feb 26, 2009 04:28 PM
synergy004
Jan 29, 2003 10:14 PM
hatchy
Apr 5, 2002 04:01 PM
