air fuel guage problem
Old Dec 9, 2002 | 02:55 PM
jas0n's Avatar
Please don't hurt me!
Default air fuel guage problem
ok heres the problem the guage dosent jump at all its moves around a little but
dosent jump around at all
i put the wire to d14 on the ecu
my car 92 vx w/ b18c1 chipped p28
my friend said i had to switch a wire for it too work is this true if so which wire
i know this guage is basically a light show but it was in the car when i had it and when i did my swap i took it out and now it not reading like before (which was a long time)
Old Dec 9, 2002 | 03:10 PM
jas0n's Avatar
Default Re: air fuel guage problem (couter)
hrmmm cant figure anything out
Old Dec 9, 2002 | 03:50 PM
tominos's Avatar
maybe your o2 isn't working. try switching to a 4 wire self heated o2.
Old Dec 9, 2002 | 06:21 PM
jas0n's Avatar
Default Re: air fuel guage problem (tominos)
yah well i have a o2 off a gsr
another problem light came up and i got oxygen sensor it only comes on rarely and its seems to be 3rd gear or higher still trying to figure out why soo its hard to find out if we fixed it or what not
Old Dec 9, 2002 | 07:17 PM
jas0n's Avatar
i think it might be my o2 sensor i might need a new 1 any other ideas?
Old Dec 9, 2002 | 07:24 PM
976's Avatar
976
New User
Check all wires, esp. ground. Are they setted properly? Did you tap the D14 wire, or just strip and eletrical tape it?
If those are good, then try replacing your o2 sensor, this might also be the case for your 3rd gear lag.
Old Dec 10, 2002 | 03:01 AM
jas0n's Avatar
Default Re: air fuel guage problem (w00t!)
the wire is done good i even solder it cause i thought that was the problem
Old Dec 10, 2002 | 03:08 AM
97hb's Avatar
Its probably the O2 sensor. Damn, those things are expensive .
Old Dec 10, 2002 | 07:24 AM
boostin b16's Avatar
just break down and buy a greddy a/f..............it comes with its own o2, relativly easy to install(just remove secondary o2 untill you can have a bung welded, and its the most accurate non wideban on the market...........i have one, turbo 8 months at 14psi daily just a/f and no prob!
Old Dec 10, 2002 | 10:02 AM
jas0n's Avatar
Default Re: air fuel guage problem (boostin b16)
im ok what with i got
Old Dec 10, 2002 | 11:06 AM
976's Avatar
976
New User
Autometer is fine at WOT, gives good readings then. Where else are you majorly concerned? At idle, who cares how rich your running at idle.
Old Dec 10, 2002 | 01:02 PM
HondaCutter's Avatar
you can get a 4 wire o2 sensor for $60 at oxygensensors.com
Old Dec 11, 2002 | 06:39 AM
degooser's Avatar
what does your gauge do when you are just driving regularly??? ex...stay rich....or what?
Old Dec 11, 2002 | 09:58 AM
jas0n's Avatar
Default Re: air fuel guage problem (degooser)
moves around a lil bit in rich some times go to stoich
Old Dec 12, 2002 | 07:03 AM
degooser's Avatar
hum...i am not sure if this is going to help, but my chipped p28 always runs in open loop when i am driving regularly.....(stays in the rich section and moves a little around in there, I get horrible gas milelage!)
I thought that my A/F gauge was broken when I first swapped my motor, but now I think its the ECU program..
have you had your chipped p28 in for a while?
Old Dec 13, 2002 | 05:17 AM
jas0n's Avatar
nope just got in chipped it started to jump around a lil bit at certain times
but not like my other friends with a p28 chipped his jumps from side to side
he said he had to wire something different to get guage to work right
1988_96hb
May 23, 2007 08:30 PM
99delsol
Oct 3, 2006 08:40 PM
TylerH
Apr 7, 2006 02:18 PM
technine
Nov 21, 2005 11:46 AM
charjacq
Mar 23, 2003 10:22 AM
