air fuel guage problem
Please don't hurt me!
ok heres the problem the guage dosent jump at all its moves around a little but
dosent jump around at all
i put the wire to d14 on the ecu
my car 92 vx w/ b18c1 chipped p28
my friend said i had to switch a wire for it too work is this true if so which wire
i know this guage is basically a light show but it was in the car when i had it and when i did my swap i took it out and now it not reading like before (which was a long time)
Re: air fuel guage problem (tominos)
yah well i have a o2 off a gsr
another problem light came up and i got oxygen sensor it only comes on rarely and its seems to be 3rd gear or higher still trying to figure out why soo its hard to find out if we fixed it or what not
New User
Re: air fuel guage problem (couter)
Check all wires, esp. ground. Are they setted properly? Did you tap the D14 wire, or just strip and eletrical tape it?
If those are good, then try replacing your o2 sensor, this might also be the case for your 3rd gear lag.
just break down and buy a greddy a/f..............it comes with its own o2, relativly easy to install(just remove secondary o2 untill you can have a bung welded, and its the most accurate non wideban on the market...........i have one, turbo 8 months at 14psi daily just a/f and no prob!
Re: air fuel guage problem (boostin b16)
New User
Autometer is fine at WOT, gives good readings then. Where else are you majorly concerned? At idle, who cares how rich your running at idle.
hum...i am not sure if this is going to help, but my chipped p28 always runs in open loop when i am driving regularly.....(stays in the rich section and moves a little around in there, I get horrible gas milelage!)
I thought that my A/F gauge was broken when I first swapped my motor, but now I think its the ECU program..
have you had your chipped p28 in for a while?
Re: air fuel guage problem (degooser)
nope just got in chipped it started to jump around a lil bit at certain times
but not like my other friends with a p28 chipped his jumps from side to side
he said he had to wire something different to get guage to work right
TylerH
04-07-2006 02:18 PM
charjacq
03-23-2003 10:22 AM
