JDM Low Beam HID cover question
Old Dec 9, 2002 | 02:08 PM
PYMUGENITR's Avatar
Default JDM Low Beam HID cover question
I bought a JDM front end conversion this summer for my 2000 Integra Type R. The guy I bought it from here in Norcal sold me the HID housings without HIDs. I purchased at set of Philips HIDs since then and they look dope. The only problem is that the stock JDM HID ballast is what seals the Low beam housing. Since I am using aftermarket HID ballast which I bolted down to the fenderwell, I have nothing to seal my housing. Does anybody have any suggestions. Has anybody made up any rubber gadgets? Right now I just have it taped to hold out the water and condensation but with the rainy season ahead......I may be in trouble....Thanks
here is a link to what I am talking about
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874364538
[Modified by PYMUGENITR, 11:13 PM 12/9/2002]
Old Dec 9, 2002 | 08:47 PM
thejdmkid's Avatar
Default Re: JDM Low Beam HID cover question (PYMUGENITR)
TAp plastic then let your hommie help you design something that is one of a kind....
Trust is the key issue...
Old Dec 9, 2002 | 08:51 PM
CrazyHondaBoy's Avatar
You need the real oem honda hid kit to bolt into hid headlight housing.
Non hid jdm headlight housing can be bolt with any aftermarket hid kit, prefer
philip hid kit.
I wouldnt try to let someone to seal into the around the hid kit,
that be a mess, get the s2000 hid kit, it fit right into it perfectly.
Old Dec 10, 2002 | 02:20 AM
ebelp's Avatar
Default Re: JDM Low Beam HID cover question (CrazyHondaBoy)
I looks like those are just plastic housings for any HID ballast. Can't you place your existing ballasts in there?
EvoMperor
Apr 4, 2008 03:30 AM
jdmtyper680
Nov 18, 2002 10:09 AM
RiCE On IcE 2
Oct 10, 2002 01:23 PM
