C.E.L. code 13 help
Old Dec 8, 2002 | 09:48 PM
n*hance*ek's Avatar
Default C.E.L. code 13 help
code 13 baro sensor [atmospheric pressure} been poping up lately, 3 times for the last two weeks, after the turbo install, i didn't remember messing with any sensor other then the i.a.t., anyone know where i should start checking,
Old Dec 9, 2002 | 07:42 AM
Kataku2K3's Avatar
Default Re: C.E.L. code 13 help (n*hance*ek)
The barometric pressure switch is built into the ECU, so i'm not sure why you would be getting a code.... What car/ECU are running...
Old Dec 9, 2002 | 08:52 AM
n*hance*ek's Avatar
Default Re: C.E.L. code 13 help (JDMspecEG6)
99si ecu in 99si with greddy blue box
Old Dec 9, 2002 | 12:18 PM
b19coupe's Avatar
Are you running bigger than stock injectors? If not, try swapping ECU for another one and see if you get the same code.
Old Dec 9, 2002 | 05:41 PM
n*hance*ek's Avatar
Default Re: C.E.L. code 13 help (b19coupe)
yea, i am running 440cc rc inj. the greddy blue box doesn't control, i been running it hella rich for 2 weeks now, waiting on for a hondata, can that be the problem
Old Dec 9, 2002 | 06:09 PM
b19coupe's Avatar
The injectors are causing the code. I saw another post on HT about the same problem. Apparently, running big injectors causes the ECU to think that there is a problem with the baro sensor. Once you get Hondata , you should be able to tune the mixture and eliminate the code.
happyabortion
May 13, 2008 04:18 PM
turbohb91
Mar 30, 2005 07:53 AM
ExVtec
Apr 1, 2004 11:02 PM
Hondasaurs
Dec 13, 2002 10:42 AM
boost killz
Sep 10, 2001 09:25 AM
