exploded tranny pic needed, please ASAP
Old Dec 8, 2002 | 08:23 PM
kranked91dx's Avatar
Default exploded tranny pic needed, please ASAP
I guy's
I looked in the search, I found nothing,
Here what I need, I have a shop manual, but the tranny view they give me is the one with a tranny that got a 3 part housing, like : bell housing, tranny gear housing, and a little cap over it, on the top. I don't know what year/model this tranny could be but my pl3/3000 housing is not made that way I am absolutly shure I can't take this apart since there is no join between.
please post a pic of an exploded view of your tanny in a shop manual. Si Btw.
thanks a lot
Kranked
Old Dec 8, 2002 | 08:40 PM
Jared's Avatar
Default Re: exploded tranny pic needed, please ASAP (kranked91dx)
http://www.hondaautomotiveparts.com/
Old Dec 8, 2002 | 09:54 PM
Louie B.'s Avatar
You have a Haynes manual, don't you......
They have 6 pics at the site above:
countershaft:
mainshaft:
housing / diff:
shift forks:
shift rods:
other half of the housing:
I have a good pic on paper that my local tranny shop let me copy out of their books, but I don't have a scanner or i'd post it.
Old Dec 8, 2002 | 09:57 PM
USDM 4G VTEC's Avatar
Default Re: exploded tranny pic needed, please ASAP (thumpu77)
go have it scanned... it will bne very helpfull for us..
i am in the wa of taking my si tranny apart and rebuilding it...
Old Dec 9, 2002 | 03:30 AM
keithv's Avatar
the pictures of the tranny in your haynes manual is for a 3rd gen civic, which as you now know is totally different than the 4th gen.
what do you need to know exactly? i know there are a few of us on the board who can answer your questions.
on a side note, i should be pulling apart a tranny soon. i hope to take many pictures of the process.
Old Dec 9, 2002 | 04:42 AM
civicwagonman's Avatar
Default Re: exploded tranny pic needed, please ASAP (breaka_1_9)
all haynes it good for is valve adjustments and timing stuff! they're not worth the money. look on ebay and get a honda manual if you can. much better.
Old Dec 9, 2002 | 02:44 PM
Default Re: exploded tranny pic needed, please ASAP (civicwagonman)
thaks for the fast answer, and the pics,
I would have ansewred sooner but I'm sick these day and have to sleep since I can't eat nothing, I don't know what is that **** but danm it suck.
I effectively got a Haynes manual, I always have doubt with it, since it's for 1984 to 1991 civic. I will have a look at the Honda motor Co book as soon as I can do it.
Is there any things to remove except the housing bolt and everithing that's bolted to the tranny housing before taking it apart ???
Kranked
Old Dec 9, 2002 | 08:19 PM
Louie B.'s Avatar
yes there is!
Once you get all the bolts out, crack the case open just a little bit. then unscrew the plug on the end of the main shaft housing (#8 in the last pic I posted) behind it you will see a spring clip going around the main shaft. use a spreader to open up the spring clip until the main shaft drops out of it's hold. then you can seperate the halves.
Old Dec 10, 2002 | 03:58 AM
just to make shure, it's the oil level check plug you are pointing me there ??
thank's
anybody else have any suggestion ???
kranked
Old Dec 10, 2002 | 05:14 AM
keithv's Avatar
thanks to serious, check out this page:
http://www.korossy.org/honda/tranny.html
Old Dec 10, 2002 | 07:38 AM
memphiss13's Avatar
how are these for exploded pics?
Old Dec 10, 2002 | 09:00 AM
Default Re: exploded tranny pic needed, please ASAP (rookie2nr)
Nope, these are busted tranny pics !!
btw nicely done !! one more dead tranny on the planet!!
what do you plan for it?? boat anchor ???
see ya
Kranked
Old Dec 10, 2002 | 11:01 AM
memphiss13's Avatar
no i gave it to my friend who put my ITR trans in. he said he'd find a use for the parts.
Old Dec 11, 2002 | 08:58 AM
Boat anchor is kind of a use for the rest of the unused part !!
rukawa1one
21
May 26, 2004 08:51 PM
Dc_John
May 11, 2004 12:01 PM
DOHC hatchback
15
Dec 3, 2003 05:00 PM
