high power on stock cams
Old Dec 8, 2002 | 08:14 PM
Cow's Avatar
Cow
Default high power on stock cams
I remember seeing a dyno/post where someone got like, 190whp out of stock ITR cams. Does anyone know what I'm talking about? Can you post the dyno? Yes I've done a search.
I'd also like the details of the particular setup if anyone knows them. Compression, supporting mods, fuel management, etc. Thanks.
Old Dec 9, 2002 | 09:15 AM
Cow's Avatar
Cow
Default Re: high power on stock cams (Cow)
Anyone?
Old Dec 9, 2002 | 09:34 AM
BABY NSX's Avatar
Try this:
https://honda-tech.com/zerothread?id=150679
Old Dec 9, 2002 | 09:48 AM
Cow's Avatar
Cow
Default Re: high power on stock cams (BABY NSX)
Damn there it is, couldn't find it when searching.
Too bad the images arent showing up.
Thanks.
Old Dec 9, 2002 | 09:52 AM
Reid's Avatar
Global Moderator
Next time, try searching in the archived topics as well as the recent topics.
Old Dec 9, 2002 | 09:57 AM
Rob Dizzle's Avatar
chris just put down 198whp with 100 octane
he had 12.5-7 CR lightweight flywheel and kosei k-1
that was the 3rd or 4th dyno run he did, and there was only 4 miles total on the motor
it was built with all honda parts by lawrence @DSR
I am going for mid 190 whp on 91 octane and 200+on 100 octane
i have not dynoed because I am saving up for a new header
my setup is
portlow inner springs
portflow ti retainer
jdm itr pistons (with head & flat valves im in the mid to high 11 cr ration)
rc 310's
gsr head with
itr cams/outersprings/lmas
REV SS valves (flat faced, oversized)
5 angle valve job
portflow cam gears
skunk2 IM
soon to have bigger TB
j's racing intake with soon to be cut-out headlight
ats fd in r tranny
comptech flywheel
hondata s200
I dont think i have seen or heard of anyone hitting 200whp on r cams with 91-93 octane
im sure it can be done though
Old Dec 9, 2002 | 10:24 AM
B2FiNiTY's Avatar
Default Re: high power on stock cams (Bob-DC2)
There are 2 people that come to mind hitting 200 or more with stock cams. Cali octane too
Old Dec 9, 2002 | 11:46 AM
neo1z's Avatar
Default Re: high power on stock cams (B2FiNiTY)
yea ive seen that a couple times....saw a 208 once.
Old Dec 9, 2002 | 11:56 AM
PM-Performance's Avatar
Default Re: high power on stock cams (neo1z)
i was making 186.4 on all stock motor with a few boltons and then gained another 9whp from the vafc tune so thats 195 and change with stock cams and all stock internals
Old Dec 9, 2002 | 09:03 PM
Cow's Avatar
Cow
Default Re: high power on stock cams (itr206)
Thanks for all the replies. I am wondering how much I can get out of ITR cams, since that is probably what I am going to be going with (poor man's ITR ).
Bob, what kind of header are you going to get?
[EDIT] I am going to be running 93 octane.. [/EDIT]
[Modified by Cow, 1:05 AM 12/10/2002]
Old Dec 9, 2002 | 09:13 PM
Paste's Avatar
Loved
Yup, EP was the first person i thought of. Either way, its going to be expensive because without extensive tuning, it will be hard to make that much power, but on the contrary, the same amount of money to make 208whp could make more power.
Old Dec 10, 2002 | 12:55 AM
Rob Dizzle's Avatar
who?
2.0 l or 1.8 l?
Old Dec 10, 2002 | 06:42 AM
Casey's Avatar
1.8l, with good parts and tuning its possible, sgt had told me of someone running 190+whp on stock gsr cams as well
Old Dec 10, 2002 | 10:52 AM
slofu's Avatar
Mike K's Bio
1998 Integra Type R #1087
Mods:
Topspeed ported cylinder head, milled .0012" (11.15:1 CR)
Toda Header w/ 2.25" test pipe
01 ITR intake cam, 98 ITR exhaust cam
OBD1 Skunk2 ECU and A'PEXi V-AFC
Comptech Icebox w/ Comptech air filter
Spoon flywheel and Exedy organic clutch
ITR trans w/ ATS 3-4-5 gearset
STOCK bottom end, STOCK exhaust and muffler!
192.4hp/134.8tq at the wheels
who doesn't see room for 7.6whp improvement? hondata, mugen headgasket, open header or better catback.
Old Dec 12, 2002 | 04:39 PM
Rob Dizzle's Avatar
Default Re: high power on stock cams (slofu)
I am not sure about clearences with adding a mugen or other thinner head gasket.
you might run outa space
could also do some 290 or 310 injectors
cool to hear though. i didnt know mike that much hp
seems like high cr is the name of the game
Old Dec 12, 2002 | 05:06 PM
Q-OnE's Avatar
damn....i hope i hit those numbers soon with all those bolt ons
Slow_import
May 20, 2012 09:05 AM
type_r_teggy
K Series
11
Feb 26, 2012 04:42 AM
spoolinvtec54
Mar 28, 2011 05:48 PM
BlackRocket
19
Nov 25, 2004 10:37 AM
TurBoTeG
Apr 21, 2004 01:33 AM
