full suspension overkill?
Old Dec 8, 2002 | 07:58 PM
98cwitr's Avatar
Default full suspension overkill?
I love my stock suspension more than any other aftermarket i've had on any of my other cars. I want my ITR lower though and i dont mind spending the money on a full suspension kit. I'm looking at getting the Tein RAs (rust sucks my ***, HAs not for me) or tanabe sustec pro SSs. Everyone is saying this is an over kill since I dont autocross but I like hauling *** around tight corners and wouldnt mind doing it faster than i already am. is a full suspension on a ITR overkill or would i be as happy with some GCs and koni yellow's?
Old Dec 8, 2002 | 08:02 PM
Ferrell's Avatar
Default Re: full suspension overkill? (98cwitr)
upgrade once you outdrive the stock suspension.
Old Dec 8, 2002 | 08:08 PM
disordeR's Avatar
Default Re: full suspension overkill? (Ferrell)
upgrade after you run some HPDE's or autocross events.
Old Dec 8, 2002 | 08:10 PM
Champ R's Avatar
If you mainly want looks with upgraded performance, get the spoon springs. Nice drop and designed to work with your stock shocks.
Old Dec 8, 2002 | 08:18 PM
98cwitr's Avatar
Default Re: full suspension overkill? (Champ R)
what kiond of drop with spoon springs?
Old Dec 8, 2002 | 08:39 PM
azn98R's Avatar
if not spoon, KG's are sweet ask Mike, here's a link: http://www.ipsracing.com/suspension/...21springs.html
Old Dec 8, 2002 | 09:30 PM
AJ PwR's Avatar
With stock wheels , Front 2 finger gab rear 1 finger gab.
Old Dec 8, 2002 | 10:21 PM
chad's Avatar
Moderator
yes this is good....
but suspension upgrade is the best mod for trackerwhores like myself
Old Dec 8, 2002 | 10:43 PM
Bbasso's Avatar
Have you done any HPDEs yet?
If not then try one and then you will learn the car even better and be able to make the biotch take turns much faster.
I know what you want, but after I went to two HPDEs I thought to myself "na don't mess around with the stock stuff it's pretty damm good"
If you think you want some more grip on the turns then Try the Falken Azenis tires on all four corners.
Old Dec 9, 2002 | 12:27 AM
kkim's Avatar
http://php.indiana.edu/~bchang/Pics/...ate_Table.html
Old Dec 9, 2002 | 04:04 AM
Asahi's Avatar
Default Re: full suspension overkill? (kkim)
No one seemed to read what he said.
He wants a lower "look" and doesn't auto-x or track the acr. He knows the stock suspension is the **** and is concious enough of that to want the lower "look" suspension to be as good or an improvement.
I would get a full suspension setup if you can afford it just to keep with the performance aspect of the car. Look at the Zeal Function B2's. MUCH cheaper and a good setup. I have the HA's BTW and no rust here. I don't live up north but I also spray them off and keep WD40 on them.
Old Dec 9, 2002 | 07:23 AM
Todd00's Avatar
I said I don't want a title!
Not everyone can or wants to drive like an F1 driver, and I think this guy is one of those folks. So, while the "learn to drive" may be good advice, let's just stick to the topic.
If you are looking for something just to lower the car a bit, Look at Spoon or KG/mm springs, or even a set of Ground Control coilovers with decent springrates for the stock shocks. You don't need to spend a grip on suspension that you'll just use on the street. I would *never* have a $2000 suspension on a dedicated street car that would never see the track.
Old Dec 9, 2002 | 07:58 AM
Young_R's Avatar
spoon
Old Dec 9, 2002 | 11:40 PM
98cwitr's Avatar
Default Re: full suspension overkill? (IntyTypeR0798)
retail on spoon springs is like 320...i would like to handle like a F1 car. What about neuspeed race springs? I really only want to drop $1500 into my suspension. I dont really want to spend more than that (since its strictly a street car, well i do go to the drag strip a lot but that deoesnt matter too much.)\
p.s. How do you like your HAs?
Old Dec 9, 2002 | 11:52 PM
B2FiNiTY's Avatar
For 1500, spend soem more for S6
Old Dec 10, 2002 | 03:27 AM
Brian's Avatar
Default Re: full suspension overkill? (B2FiNiTY)
For 1500, spend some more for S6
Definitely. That would be my route too if I had $1500
Old Dec 10, 2002 | 03:49 AM
98cwitr's Avatar
Default Re: full suspension overkill? (Brian)
s6?
Old Dec 10, 2002 | 04:42 AM
Brian's Avatar
s6?
Zeal S6
Old Dec 10, 2002 | 05:04 AM
Back in Black's Avatar
Rather OG
Default Re: full suspension overkill? (Chad)
what hatchcrap-sissy said
Old Dec 11, 2002 | 01:09 PM
98cwitr's Avatar
Default Re: full suspension overkill? (Jason Franza)
would Zeal b2s be better than Tein RAs?
[Modified by 98cwitr, 5:10 PM 12/11/2002]
omiehomie
Jan 26, 2010 01:39 PM
ej_randy
Mar 27, 2007 06:55 PM
FBP#494
Mar 6, 2003 03:57 AM
slimbo
Sep 30, 2002 11:18 PM
CKDC2
Mar 5, 2002 09:32 AM
