My $6 Manual Boost Controller.....(Home Depot)
Old Dec 8, 2002 | 06:27 PM
TheIntegraGuy's Avatar
Default My $6 Manual Boost Controller.....(Home Depot)
Well...I finally made another MBC courtesy of http://www.c-speedracing.com. I've always wanted to do it but I was always too lazy since I had a GReddy MBC but now it's broken. Anyways, here is a site that shows you step-by-step on how to do it. I'm sure some of you know that this is yesterdays' news but for the new darkside people here it is....
http://www.c-speedracing.com/howto/mbc/mbc.php
Not my motor, nor my hands, but it looks exacty like it...
Pics are courtesy from http://www.c-speedracing.com
It's "suppose" to cost $4 but Home Depot only sells the fittings in pairs, thus 2 MBC's that I can make. Hehe. So it's not that bad. I paid $6 all together. Works great but I got a few questions....
It boosted really great...From .5 BAR to .8 BAR and I'm too lazy to calculate the PSI but I'm guessing on the top of my head around 10-12 PSI'ish... Pulls great but the BOV sounds like ****. Sound's like it's way too tight and not letting any air out. Compressor Surge coming along maybe? Anyways, I'm suppose to adjust the BOV again correct? I'm pretty positive but I just want to make sure...
-ThankS...
Old Dec 8, 2002 | 06:29 PM
zojirushi's Avatar
Default Re: My $6 Manual Boost Controller.....(Home Depot) (Esone3)
gotta be careful with those homemade mbc's. They tend to stick open and cause overboosts.
Old Dec 8, 2002 | 06:43 PM
Tofurky's Avatar
Default Re: My $6 Manual Boost Controller.....(Home Depot) (zojirushi)
yeah... like setting it to 7 psi, then all of the sudden seeing 13?
definitely be careful with them.
Old Dec 8, 2002 | 07:33 PM
Farnsrocket's Avatar
Default Re: My $6 Manual Boost Controller.....(Home Depot) (Ruckus138)
Yep, I made one once and could just never get it to set right.......probably needed a different spring........too inconsistent.
Old Dec 8, 2002 | 07:49 PM
SlowB16's Avatar
Default Re: My $6 Manual Boost Controller.....(Home Depot) (Farnsrocket)
it seems like if the spring was a tad thicker and was as wide as the inside of the fittings, so it was snug up aginst the walls it would work pretty well......I bet the boost creep has something to do with that spring being sideways when you tighten the thing down
Old Dec 8, 2002 | 08:40 PM
Default Re: My $6 Manual Boost Controller.....(Home Depot) (SlowB16)
actually, I got a thicker spring cause I thought the same...That small spring will eventually weaken and cause it to bend sideways...and that's a NO NO...But over all, mines is working great....I like it. Ofcourse my GReddy MBC was better, but it was broken...and I couldn't find a similar regualtor at home depot.
Old Dec 8, 2002 | 08:44 PM
PeakBoost's Avatar
B*A*N*N*E*D
here is our version of the greddy mbc http://store.yahoo.com/cheapturbo/commanboosco.html
Old Dec 15, 2002 | 09:54 PM
shortyz's Avatar
Default Re: My $6 Manual Boost Controller.....(Home Depot) (CHEAPTURBOdotCOM)
im bringing this up from the dead. but cheap turbo. does that thing work well?
also. does the boost controller go from wastegate to turbo piping?
Old Dec 15, 2002 | 10:14 PM
Daniel's Avatar
Hmmm, yeah, i think i might just have to do this over Winter Break. so EVERYTHING is available at Home Depot? even the ball bearing? Does Home Depot also sell the vacuum hoses? because if i do the homemade MBC, i want to lengthen the hose from the WG to the turbo since it's just barely long enough. i don't want the MBC sitting that close to the turbo.
i've seen this article, too but have also been a little lazy.
[Modified by Daniel, 7:14 AM 12/16/2002]
Old Dec 15, 2002 | 10:38 PM
shortyz's Avatar
Default Re: My $6 Manual Boost Controller.....(Home Depot) (Daniel)
the only thing i dont like about that spring one is that u cant regulate it.
i mean u can buy regulators for small airbrushes.
Old Dec 16, 2002 | 12:18 AM
SIK IN DA HED's Avatar
New User
yep... exactly why i ordered one proven to work instead. (joe p)
Old Dec 16, 2002 | 06:50 AM
E-Rok's Avatar
EPIC TUNING
Default Re: My $6 Manual Boost Controller.....(Home Depot) (dlplayboy)
or you can buy a pressure release valve for $15.....
JOSEPH
Aug 23, 2007 12:32 PM
JOSEPH
Aug 17, 2007 08:07 AM
Sinner
May 3, 2005 10:05 AM
Acura_I-RS
Mar 30, 2003 02:20 PM
marklamond
May 10, 2002 02:17 AM
