Need help quick... compression test bolt stuck....
Old Dec 8, 2002 | 03:57 PM
Eluzion's Avatar
Default Need help quick... compression test bolt stuck....
At a friends house right now... was doing a compression test but....
the part that you screw into the spark plug spot came off when I was unscrewing the hose and now I have no idea how to get it out. Tried screwing the hose back in to the head piece but when I unscrew it, the hose just keeps coming out.
Any idea how to get this out? The only socket size that fits is too big to even fit down that hole.
Need to get this fixed asap cuz I need the car.
Old Dec 8, 2002 | 04:21 PM
SuperSH's Avatar
Default Re: Need help quick... compression test bolt stuck.... (Eluzion)
Have you thought of superglue on the threads? I would say blue locktite but that takes too long. Thats the only thing I can think of.
Old Dec 8, 2002 | 04:25 PM
Desslok's Avatar
Default Re: Need help quick... compression test bolt stuck.... (SuperSH)
Maybe take the cam cover off, see if you have more room?
Old Dec 8, 2002 | 04:47 PM
t0p_sh0tta's Avatar
Default Re: Need help quick... compression test bolt stuck.... (sp)
Try super glue or thread lock.
Old Dec 8, 2002 | 04:55 PM
ImportRacing's Avatar
Default Re: Need help quick... compression test bolt stuck.... (REVOEVOM)
This happen to me and what I did was take a Long screw driver that was thin and stuck it into the small hole.
Old Dec 8, 2002 | 05:30 PM
Eluzion's Avatar
Ahh got it... went to schucks and picked up some really long needle nose pliers.... couldn't grab around it so just put it in and pulled the pliers apart (so they would grab inside the bolt) and twisted.
Thanks to everyone for the help though.
I think I'm going to take this piece of crap compression tester from Harbor Freight back. Schucks had a really nice one that's all one piece so you don't have to worry about it coming off but it's $30 for regular and $40 for the one with the steel braided hose....
Old Dec 8, 2002 | 10:33 PM
Muckman's Avatar
Moderator in Chief
I had this exact same thing happen in my engine. We were able to just rescrew the hose onto the spark plug thing and it was enough to loosen the entire unit.
Luck6
24
Jun 13, 2015 04:50 PM
gjbraun
Jun 18, 2012 10:57 AM
hometheaterman
Apr 3, 2010 10:44 AM
geminis2k
Dec 7, 2002 05:17 AM
geminis2k
Dec 5, 2002 09:13 PM
