How can you spot lsd
Old Dec 8, 2002 | 12:39 PM
ATL-R's Avatar
Default How can you spot lsd
Quick question, is there a way to tell if a transmission has Lsd without having to open it up, and without installing it. I have a friend who just bught a JDM "Type R" tranny and needs to know asap. thanks in advance for answering my n00b question.
Old Dec 8, 2002 | 12:44 PM
yellow blur's Avatar
Default Re: How can you spot lsd (ATL-R)
Jack up the front and turn one wheel. The other side should be spinning the other way.
Old Dec 8, 2002 | 12:46 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How can you spot lsd (yellow blur)
Old Dec 8, 2002 | 12:55 PM
StinkyTofu's Avatar
Default Re: How can you spot lsd (Rguy)
How about before having the tranny installed, anyway to tell if it doesn't have the LSD stamping?
Old Dec 8, 2002 | 01:08 PM
baonest1's Avatar
Default Re: How can you spot lsd (StinkyTofu)
look through the axle hole... i hear there should be no bar. it should be straight through
Old Dec 8, 2002 | 02:13 PM
vteg's Avatar
New User
This may not work. Put the car in gear, and then turn the wheel. It should then spin the opposite direction. The other wheel may spin either direction if the car is not in gear.
Just read tranny is not in yet. Just look through the axle holes, there is no pin. You should be able to see straight through.
[Modified by vteg, 3:15 PM 12/8/2002]
Old Dec 8, 2002 | 06:04 PM
ATL-R's Avatar
i said without having it installed, so there is no way to make it run, explain the tranny hole to me again???? the jspec ones dont have the lsd stamping.....
Old Dec 8, 2002 | 06:11 PM
Nameless RB26's Avatar
That's not the way to test for an LSD. That's the test to see if the LSD in operating correctly.
Open differentials spin oppisite direction too.
If you want to know whether you have an LSD, do a burnout with the wheels straight, you'll hear both tires spin. And... punch the gas going around a corner (you'll feel it - do it safely)
The best way to see it, is to take the tranny off and look through the midshaft/axle hole. If you can see straight through it, you have an LSD. If you see something in the middle, that's an open diff.
Old Dec 8, 2002 | 06:34 PM
baonest1's Avatar
Default Re: How can you spot lsd (Nameless)
see where the axle goes, you should be able to see through it clearly with no bar, mine might be hard to see but there is a white thing on the under the tranny.
Old Dec 8, 2002 | 07:00 PM
Dave-ROR's Avatar
Default Re: How can you spot lsd (vteg)
Old Dec 8, 2002 | 07:13 PM
ATL-R's Avatar
is there any difference between the jdm and usdm trannies, becaues I bought this one from an acura dealership and they told me it was a jdm type R tranny. and there is a pin running through the axle hole, can anybody help???
Old Dec 8, 2002 | 07:39 PM
baonest1's Avatar
the one in the pic is a JDM tranny.. looks like you dont have LSD. better go back to dealership.
EuroR_TSX
May 11, 2008 11:09 PM
JDMbull
Aug 24, 2006 07:15 AM
bracket 4 life
Apr 23, 2005 03:31 AM
THEROPE
Mar 26, 2005 07:29 AM
JSJ EG6
Apr 17, 2003 07:41 AM
