253.4 whp and 209 lb-ft
I made 253.4 whp and 209 lb-ft at about 8 psi (blue line). The red line was my baseline run and that was done with wideband O2 street tuning. With street wideband tuning, I made 258.1 whp and 207.7 lb-ft but the a/f curve was a little bit lean up top.
Here is my setup:
1999 Honda Prelude Type SH
AEM EMS
RC 440 high impedence injectors
FJO wideband O2
Portflow PnP head
entire Ferrea valvetrain with 0.5 mm SS valves on intake and exhaust
Cometic HP style 0.057" headgasket
modified Fmax kit
Garrett T3/T4E stage 3 w/0.63 a/r and 60 trim w/0.60 a/r
2.5" testpipe and Apexi N1 exhaust
I want to thank John (Vaportrail) for letting me use his dyno at great prices and for giving me tuning tips. I highly recommend him.
[Modified by Quaalude, 4:11 PM 12/8/2002]
Here is my setup:
AEM EMS
FJO wideband O2
Portflow PnP head
modified Fmax kit
Very Nice!A leetle lean around 4000 rpms tho.
Nice numbers. What have you done to the bottom end? And what psi is the plot of?
Wow that is nice. How long do you think it will last @ 8psi on the stock bottom end?
Even with good tuning I have always heard that h22 rings are weak as applesauce..
those are pretty good numbers but, expected more torque from a prelude motor. i made something similar with a ls motor.
Hopefully, the ringlands will last until I have the funds to build up my spare h22a1.
[Modified by Quaalude, 5:21 PM 12/9/2002]
[Modified by Quaalude, 5:22 PM 12/9/2002]
I also have a stock bottom end with an inlinepro headgasket that lowers compression to 9:1. I;m goin to street tune this week with a greddy emanage. With a good street tune would you think its ok to tune at 11psi at high boost(track). Daily boost set at .65 bar with wastegate. Did u use the autotune feature on your aem ems?
walbro 255 intank fuel pump
aem cam gears
2.5 testpipe
apex n1
aem cam gears
2.5 testpipe
apex n1
Those are nice numbers
where'd you buy your FJO? I'm taking my car there Saturday for it's rebuild. Did you show John any tricks with the EMS?
[Modified by Mikeyslude, 3:25 PM 12/11/2002]
where'd you buy your FJO? I'm taking my car there Saturday for it's rebuild. Did you show John any tricks with the EMS?[Modified by Mikeyslude, 3:25 PM 12/11/2002]
vtec.dc2
Aug 22, 2002 02:58 PM
