an someone please answer my question about my bottom end?
JE 9:1 Comp. Pistons
Eagle Conn. Rods
ACL Engine Bearings
ARP Headstud Kit
Cometic Headgasket
STR Block Gaurd
On a B18C1 with a stock head, tuned with Hondata and 550cc Injectors.
I want 300 WHP on pump gas and 350-375 on race gas.
Can this be done safely and reliably if tuned properly?
And how much is it to sleeve the block 84mm from GE?
Thanks. Michael
Eagle Conn. Rods
ACL Engine Bearings
ARP Headstud Kit
Cometic Headgasket
STR Block Gaurd
Thanks. Michael
You should be cool but I would lose the block gaurd. I would rather run just stock sleeves. Ge sleeves I believe are about $800-900 someone correct me if wrong. Dartons are going to run about $1000-1100 installed. But stock sleeves will probally hold up with proper tuning
dunkd
May 31, 2004 08:06 PM
DamonBoost
Dec 13, 2001 08:46 AM
dohc_Cx
Nov 2, 2001 01:43 PM
