cant get the pulley on the crank off...
You have to get a crank pulley tool made by moroso from summit, and a really long extension to you breaker bar. I'm talking about 4 ft long. Also if the engine is in the car, try putting the car in 5th gear, and have some one step on the brakes while you loosen the bolt. Good luck.
my manual saids to use the flywheel..
using the term "crank pulley bolt" in the 'archives'...
you will find a multitude of responses and many wacky ways of removing the bolt...
t..
sayanything
Sep 22, 2010 04:47 PM
