ECU???????
Old Dec 7, 2002 | 11:41 AM
RISING SUN RACING
Guest
Posts: n/a
Default ECU???????
Dose anyone know why on the side of my ECU there is a long black screw? A freind said that i could advance nad retard my spark with this. he said turn to left advace and turn right retard. if i play with this will i **** up my ignition and is there any advantge to tune with this?
any info will help!
Old Dec 7, 2002 | 11:47 AM
Kataku2K3's Avatar
Default ecu
And what kind of car is this??? I've never seen or heard of that before on a Honda but then again maybe I've always missed something.... You sure he isn't talking about rotating the distributor to advance or retard.... Peace
91DA9's Avatar
Default a
What ECU are we talking about?
Normally you advance and retard ignition timing by rotating the distributor.
Old Dec 7, 2002 | 12:05 PM
RISING SUN RACING
Guest
Posts: n/a
Default Re: a (94IntegraGSR-OVR)
its a 93 civic hatch cx
Old Dec 7, 2002 | 12:19 PM
Kataku2K3's Avatar
Default ecu
Okay this is a bunch of **** then... Who is this friend?? Does he seriously think he knows what he is talking about??? If you wanna advance or retard your timing, rotate the distributor counter clockwise when standing on the passenger side of car and looking at the distributor to advance... and the opposite to retard...
Old Dec 7, 2002 | 12:53 PM
RISING SUN RACING
Guest
Posts: n/a
Default Re: ecu (JDMspecEG6)
is it hard or can i just rotate without taking out bolts and will this make a diffrence
Old Dec 7, 2002 | 01:21 PM
Kataku2K3's Avatar
Default ecu
Yea all you have to do is loosten the bolts up a bit... With a SOHC you probably won't notice to much of a difference if you advance but you'll be able to feel retard.. It is best to use a timing gun but with that motor i don't think it matters... Just advance till it begins to ping if it does then retard it a bit from that... Good Luck
Raleigh21native
Apr 18, 2018 05:13 PM
sleeperb16a
Nov 5, 2004 10:04 AM
yeegsr
Oct 19, 2004 10:14 PM
DutchITR1689
Oct 12, 2004 01:17 PM
macdaddy
Apr 30, 2002 07:56 AM
