h22a1 and h22a4 oil pan the same?
Old Dec 6, 2002 | 08:25 AM
fastludeh22's Avatar
Default h22a1 and h22a4 oil pan the same?
i can get a h22a4 one w/oil return already welded in and was wondering if it was the same. thanks
Old Dec 6, 2002 | 08:43 AM
ludespeeder's Avatar
Default Re: h22a1 and h22a4 oil pan the same? (fastludeh22)
I'm pretty sure you'll be fine. I think they are basically exactly the same. I know a guy with a h22a4 on a h23a1 so if that will work I don't see why it wouldn't fit an h22a1.
Old Dec 6, 2002 | 09:08 AM
Honda318dx's Avatar
Default Re: h22a1 and h22a4 oil pan the same? (ludespeeder)
Yes, they are interchangeable, the h22a4 pan is Aluminum, so if the return line is welded in, be careful, its difficult to weld AL.. H22a1 pan is steel
Old Dec 6, 2002 | 10:15 AM
Default Re: h22a1 and h22a4 oil pan the same? (Honda318dx)
I just thought of 1 more thing, you think the return is going to be in the right spot? being they are different gen cars, it might not work on my 93.
Old Dec 6, 2002 | 10:36 AM
bambooluv's Avatar
I thought they where different but than again I've never tried swaping them . the A4 doesnt it use a non gasket seal (you just put honda bond everywhere ) and the old school A uses a rubber gasket-my 2 pennies-pdang
NAEGH22
Nov 5, 2006 01:21 AM
B18c1turboedEK
Feb 21, 2005 10:32 AM
Hyaboosta
Jan 24, 2005 02:21 PM
Sinner
Oct 8, 2004 09:21 AM
yusoslo
Mar 21, 2004 09:24 PM
