Can I use this Fuel Filter?
Ive got one of these competition rusself fuel filters. (-6 AN)
Can and SHOULD i ditch my stock fuel filter and run this on the street??????(the filter itslef is really small.. about 2-2.5" long )
Im going to be running bosch pump, and stock lines.
[Modified by SiRkid, 3:56 PM 12/6/2002]
[Modified by SiRkid, 4:04 PM 12/6/2002]
i havent looked at my car or my stuff in a while..the stock fuel filter is soo much bigger than this thing...
anyone else have an opinion.
If you can, keep the stock fuel filter!
The only real reason why anyone would want to use the russel or aeromotive fuel filter is when they go with a big external fuel pump with steal braided lines from the pump to the rail.
Also a word of advice, If your going to use the russel or aeromotive use the PAPER ELEMENT. The metal element for aeromotive is only 100 micron. The bigger the micron the better!!!
I'm guessing a higher micron means better flow, but then lets through bigger particles.
100 micron = the "weave" is bigger so bigger particles will go through. Flows better.
1000 micron= the "weave" is small so only very little particles can go through.
I would recommend a filter before your bosch pump. You want to make sure crap from the tank does not clog the fuel pump. Consider it cheap insurance.
I would use that one over the stock stuff. I put mine on in the summer time and I picked up 3 extra psi by ommitting the stock fuel filter. Stock filter has too many bends in it. First going in the filter , then inside the filter and another bend coming out. I think the stock filter is a pain in the *** to change and was not meant for high hp applications. Keep it simple and get rid of the stock stuff. It will make your life alot easier in the future.
So for better "filtering" you want as small a number as possible......of course that won't flow as well (ie, don't use the 0.22 micron filters I use on a daily basis for your car!)
Not flaming, just FYI. Don't want someone to buy something with the incorrect info.
Steve
hmm..i dont know if i should ditch the stock filter.. i just remember seeing someones car (Forget who..black eg) with an aeromotive pump and filter and the filter is huge compared to mine..it kinda seems to small.
