Just ran my best 1/4 mile ET so far!! all motor!
went to the track, normally i run open header ect...but didnt feel like it....pulled a 14.006 @ 100.58.....cai/greddy header/N1 exhaust, vafc, cam gears....street tires pulling 2.18 60 ft....in 74 degree weather, soooooo freaking close.... 6 thousnadths of a damn second....ugh...hopefully my 13s are coming soon...peace
RT...... .544
60'...... 2.182
330..... 5.995
1/8th... 9.095
mph.. 79.61
1000.... 11.759
1/4..... 14.006
mph.... 100.58
60'...... 2.182
330..... 5.995
1/8th... 9.095
mph.. 79.61
1000.... 11.759
1/4..... 14.006
mph.... 100.58
RT...... .544
60'...... 2.182
330..... 5.995
1/8th... 9.095
mph.. 79.61
1000.... 11.759
1/4..... 14.006
mph.... 100.58
60'...... 2.182
330..... 5.995
1/8th... 9.095
mph.. 79.61
1000.... 11.759
1/4..... 14.006
mph.... 100.58
So... once I get my H22A swap slammed into my 2800 lb. accord 5 spd, add i/h/e vafc and cam gears.. i should be hitting under 14.0 w/ a good launch ?
sounds promising...
bastard hit 13's already!
No dude preluderacer has a freak car, I'm convinced he has a badass short geared tranny, and he's got lots of good bolt-on's and a spoon ecu I believe. It's still hella impressive.
[Modified by satan_srv, 10:06 AM 12/6/2002]
that's amazing
. if I can get close to that with my car when I get those mods I'll be very happy.
Any weight reduction ? This IS a prelude body right ?? Clocking in at around 3000 lbs ? Almost hard to beleive.
It's not that hard to believe. Two years ago VeeTec (Warren) was running consistant 13.8-14.0 on street tires with just bolt-ons and a full interior in a 93 VTEC.
Andrew
4th gen VTECs weigh 2800lbs max. With a 1/4 of gas and no spare or jack, they are right around 2750lbs.
92-96 VTEC
2932 lbs. to be exact.
92-96 VTEC
92-96 VTEC
Andrew
as i understood it, the 4th gens were always in the 2900-2950 range. maybe aklucsarits is right though. i never had my car weighted.
but ECHC minimum weight for the 4th gen is 2725, which was based upon Corey's weight last season. his race car is pretty damn stripped with plugged sunroof, etc.
if you take the back section out of a 5th gen (spare tire, jack etc) and the rear seats and rear side panels.. plus rear deck, you'll weigh in at around 2840-2860 with half a tank of gas. that's also with a full set of parts under the hood
ok WTF? u say manufacturer says 2932 but they are actually less? so about 2800? when my car got smogged it was weighed too.. it was 3125 lbs!!!!!!!
u guys think someone was in my car at the time ? the car was bone stock at the time.
[Modified by visualvb, 5:17 PM 12/6/2002]
Warren also figured out some way to successfully perform 7000 RPM launches on those Toyo street tires...
Paul
Paul
Nice time, thats crazy. You need to dyno that baby and see what your putting down. I know some of us running a 50-60 shot of nitrous on run similar times. Either you have a freakishly great Lude, or are one of the best drivers to ever run a Prelude at the track.
Paul
How is that possible? When your in neutral, you can't rev past 6500rpm.
Paul
RT...... .544
60'...... 2.182
330..... 5.995
1/8th... 9.095
mph.. 79.61
1000.... 11.759
1/4..... 14.006
mph.... 100.58
60'...... 2.182
330..... 5.995
1/8th... 9.095
mph.. 79.61
1000.... 11.759
1/4..... 14.006
mph.... 100.58
