Just curious, max compression for a C5?
Old Dec 5, 2002 | 08:25 PM
Kev95lx's Avatar
Default Just curious, max compression for a C5?
I'm just curious, what would be the max (read: safe) compression for a daily driven type-r?!
Old Dec 5, 2002 | 09:51 PM
function83's Avatar
Default Re: Just curious, max compression for a C5? (Kev95lx)
i would say 12 to 1.
Old Dec 5, 2002 | 10:02 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
What octane? Some of us can get 93 octane at every gas station if not more.
Old Dec 6, 2002 | 02:54 AM
Kev95lx's Avatar
Default Re: Just curious, max compression for a C5? (ActiveAero)
Max i can get here in Montreal is 92/91
Old Dec 6, 2002 | 04:41 AM
ZygSpeed's Avatar
Default Re: Just curious, max compression for a C5? (George Knighton)
Is Canadian octane the same as the US compromise method?
I would expect so, esp. with the numbers he'd given.
Old Dec 6, 2002 | 06:30 AM
Hooch'n's Avatar
Default Re: Just curious, max compression for a C5? (Zygspeed)
Compression: I'd say higher then 12.1, not sure.
Daily driven: probably 12.1 would be OK on pump gas....
[Modified by Hooch at 8400-RPM, 7:31 AM 12/6/2002]
Old Dec 6, 2002 | 08:44 AM
NSX Bob's Avatar
New User
Even more important than the availability of 93 Octane as opposed to 91 Octane is the tuning involved. Proper setups can run much higher than 12:1 w/ proper tuning on pump gas, and they will still be fairly reliable.
Old Dec 6, 2002 | 08:46 AM
ITR21's Avatar
Default Re: Just curious, max compression for a C5? (Itr00-1374)
Here in the toronto area and the rest of ontario 94 octane is readily available at sunoco stations, I know of 2 people running around 13:1 CR on there daily drivers. Im surprised that you can not get 94 octane fuel in quebec.
Old Dec 6, 2002 | 08:47 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Just curious, max compression for a C5? (ITR21)
id say 12:1 on 93.
Old Dec 6, 2002 | 09:08 AM
514_type R's Avatar
Default Re: Just curious, max compression for a C5? (integra707)
kev, go to petro canada, we get 94 octane!!
so considering that we get 94 octane, you can run 12.1 Cr with the timing set at 14 degree
my car has 11.1 cr and my car was dooing some ping with the 91 octane and timing set at 18. Now its back at 16 and im using 94 ocatne and the car run amazing!
Old Dec 6, 2002 | 12:25 PM
dohcsideSi's Avatar
Default Re: Just curious, max compression for a C5? (514_type R)
with 94 octane you should be able to run around 13:1 it really depends on your cam setup though.
Old Dec 6, 2002 | 01:56 PM
Kev95lx's Avatar
Default Re: Just curious, max compression for a C5? (dohcsideSi)
A friend of mine told me i'd need a chip or a stand alone to get the most out of a 11.5:1 CR
Old Dec 6, 2002 | 01:59 PM
Rob :190:'s Avatar
it definately wouldnt hurt
Old Dec 6, 2002 | 02:11 PM
Type-Rare#1248's Avatar
Default Re: Just curious, max compression for a C5? (Rob :190:)
in vancouver, you get 94 octane anywhere!!!
btw, chevron ownz y0
Old Dec 6, 2002 | 02:49 PM
es four's Avatar
Default Re: Just curious, max compression for a C5? (Type-Rare#1248)
I envy your supreme octane.
Old Dec 6, 2002 | 03:04 PM
MackSpeed-616's Avatar
i ran 12.2 with jun3s on 93 with no prob at all
next setup will be 12.8:1 on 93
Old Dec 6, 2002 | 04:37 PM
get wet racing's Avatar
Default Re: Just curious, max compression for a C5? (BustaNutt-616)
I'm from Montreal and I get 94 allways for my car, go to petro canada.
Old Dec 6, 2002 | 10:49 PM
Kev95lx's Avatar
We don't even get Sunoco's here in Quebec anymore!
As for Petro-Canada's 94..I've been reading too many bad stories about it, and the addictives that they add in it.
I'd be running 11.5:1..maybe 11.8:1 with CAT Stage 2 Race cams.
Old Dec 6, 2002 | 11:25 PM
uNF$@#!'s Avatar
20:1 for sure.
Old Dec 7, 2002 | 03:30 AM
threatcon13's Avatar
New User
Default Re: Just curious, max compression for a C5? (Soup ****)
20:1 for sure.
Old Dec 7, 2002 | 09:48 AM
TriK's Avatar
kev... 11.91 @ 121 mph.. Only with the 94...
stop read stupid thing about gaz.. and just try it..
if it work for me.. it will work for you
here the only choice it's the petro canada 94 , detonation start with 92 and less
Old Dec 7, 2002 | 09:58 AM
Shane54's Avatar
Default Re: Just curious, max compression for a C5? (TriK)
I'm running 11.2:1CR and even though 92 will do the job, I prefer the 94 from Petre-Canada. What bad things have you heard about Petro-Canada? I'm curious since I've been using this gas since I did my motor.
Old Dec 7, 2002 | 12:37 PM
Kev95lx's Avatar
Default Re: Just curious, max compression for a C5? (Shane54)
Shane, just from stuff that I've read on MR.com..
http://forums.montrealracing.com/sho...ht=PetroCanada
But if the P-C 94 is good and safe, then I've got no choice. Thanks Trik/Shane.
norcalbayboy
29
Aug 7, 2006 10:08 PM
hondab18civic
Feb 6, 2006 07:24 AM
donnjuan2point2
Jul 5, 2003 03:19 PM
sneakychaos
Jun 28, 2002 09:45 PM
Rocket
May 5, 2002 12:32 PM
