Question about stock SOHC VTEC engine specs
Old Dec 5, 2002 | 08:23 PM
Mefain's Avatar
Default Question about stock SOHC VTEC engine specs
ive looked all threw the forums and couldnt find this answer
im trying to find out the stock vtec activation for a D16Y8 and if its good to stay in VTEC as you shift or if you want to "fall out" of VTEC...someone please help me out...thank you
Old Dec 5, 2002 | 09:21 PM
Diablo Tejano's Avatar
Default Re: Question about stock SOHC VTEC engine specs (NjoySleepn)
from a drag racing perspective:
ideally, when you shift you want to stay on the big lobe. if you are falling onto the smaller lobes (less lift & duration) you will be making less power thus (slightly) slower ET's. i used to hold the revs @6K and feather the clutch in my b16 EK so it would launch in VTEC, shifted @8200 and ran a best of 14.9XX @ 90mph w/ only an intake and KumHo's. I dont know when the X-over is on a y8 but you should be able to see, hear, feel the cam switch over.
james
[Modified by bluboy, 12:22 AM 12/6/2002]
Old Dec 5, 2002 | 09:25 PM
EFing8's Avatar
Default Re: Question about stock SOHC VTEC engine specs (bluboy)
His vtec is not set at the stock point and he want's to know where stock point is.
Old Dec 5, 2002 | 09:27 PM
USDM 4G VTEC's Avatar
on a Y8 its 5200...
and yes its better to stay on vtec when u shift... u got more power available 4 u...
Draiga1988
96
May 26, 2024 05:39 AM
Raven82
13
Oct 18, 2008 11:26 AM
maal15
10
Apr 21, 2008 07:34 PM
demian22
Jan 11, 2008 04:55 PM
VTgringo
26
Mar 11, 2004 01:52 PM
