clutch and flywheel upgrade for 91 accord ex coupe
Old Dec 5, 2002 | 06:46 PM
cyrixvsp2's Avatar
Default clutch and flywheel upgrade for 91 accord ex coupe
My car has 170k miles on it and the clutch is slowly dying so soon i'm going to want to replace it. I'm thinking i want to put a new clutch in it, a performence clutch to handle some more power and get better launches and with that i'd like to put a lightened flywheel. I was curious what everyone uses and what people recommend. I would rather not spend a lot of money. I see that an exedy racing clutch seems to be fairly priced but i can't seem to find a good flywheel combo. Neuspeed has a nice clutch but it's 450$. That's a little high priced for me. Anyways, suggestions are needed. thanks for your help. also include where to get them and the best prices.
oh, if you didn't see in the title this is a 91 accord ex coupe
P.S. How do I get authorized to post more than 5 times in an hour? i'm restricted still.
Old Dec 6, 2002 | 04:32 AM
kentucky accord's Avatar
Default Re: clutch and flywheel upgrade for 91 accord ex coupe (cyrixvsp2)
i run the ACT street disk and HP pressure plate with the ACT flywheel. the ACT wheel is just a lightened stocker so its not as expensive as the chromoly wheels but its also a little heavier than the chromoly.
i think i picked up the flywheel for like 90 bucks and the clutch for about 200. i run slicks and generally abuse my car pretty bad and i havent had any problems at all. the pedal effort is stock and engagement is smooth.
Old Dec 6, 2002 | 10:09 AM
cyrixvsp2's Avatar
Default Re: clutch and flywheel upgrade for 91 accord ex coupe (kentucky accord)
ttt
Old Dec 6, 2002 | 12:04 PM
smokin rubber's Avatar
ttt
how about a search
Old Dec 6, 2002 | 05:36 PM
cyrixvsp2's Avatar
Default Re: clutch and flywheel upgrade for 91 accord ex coupe (smokin rubber)
i'm not stupid, that was my first try. i got one return on "clutch" and on "flywheel" and it was about some guy wanting to know if he could chirp the tires or something stupid. Basically everyone just flamed him, no info on clutches. thanks for your help, i might not have found the search button without someone saying something me being dumb and all.
Old Dec 6, 2002 | 05:47 PM
WhoNeedsVtec's Avatar
since when does ACT make a flywheel for an accord....
exeedy clutch/flywheel seems to be popular or clutchmasters stage 1 clutch and their flywheel is also good (its alittle more expensive)
Old Dec 6, 2002 | 06:06 PM
Default Re: clutch and flywheel upgrade for 91 accord ex coupe (WhoNeedsVtec)
i didnt say that ACT made one. i said ACT takes a stocker and machines the crap out of it and makes it lighter.
keep in mind that this is a good route to take for an accord because it helps keep the low end torque our cars are known for. a lightened flywheel and the h22 tranny on the f22 motor make a lovely combo.
Old Dec 6, 2002 | 08:54 PM
oh i read it wrong..right on
Old Dec 8, 2002 | 07:13 AM
https://honda-tech.com/zerosearch
so when you go here you need to change the "data set" to archived topics. You are corect that there are only a couple recent entries on the subjects but that is partially because they have been well covered in the past.
Old Dec 10, 2002 | 07:33 AM
cyrixvsp2's Avatar
oh cool, didn't know that. thanks
typhoon
Jul 24, 2008 12:04 PM
icer5160
Feb 7, 2006 12:45 PM
808draggers
Sep 21, 2005 12:19 PM
Manguish
Jun 14, 2003 01:26 PM
Mark
Jun 4, 2003 03:35 PM
