Which ump ls/VTEC
Old Dec 5, 2002 | 05:29 PM
Stop the Beast's Avatar
Default Which pump for ls/VTEC
Which oil and water pumps will compatible with an B18A/B block? I'm trying to find out if I can use any of the B16 oil pumps I have lying around.
[Modified by FFgeokstar, 7:35 PM 12/5/2002]
Old Dec 5, 2002 | 06:02 PM
Kataku2K3's Avatar
Default Re: Which pump for ls/VTEC (FFgeokstar)
Yup it will bolt straight onto it... VTEC water pumps and oilpumps are both interchangeable on non VTEC blocks... Thank god... haha
Old Dec 5, 2002 | 10:42 PM
salbaje's Avatar
yea use any waterpump
Old Dec 6, 2002 | 06:01 AM
NA EJ1's Avatar
Default Re: Which pump for ls/VTEC (salbaje)
i wouldnt use just any pump...definetly use a VTEC water pump with the matching timing belt and a VTEC oil pump as well, the stock LS pumps are not reliable once you throw a VTEC head in the mix...HTH
[Modified by CC94B18, 10:02 AM 12/6/2002]
Old Dec 7, 2002 | 04:26 PM
Default Re: Which pump for ls/VTEC (CC94B18)
Now I'm finding that only a GSR oil pump will work, are we in aggreance?
Old Dec 7, 2002 | 04:32 PM
icelarry27's Avatar
thats what my bro had to use for his ls-vtec setup
Old Dec 7, 2002 | 09:07 PM
Jeff C's Avatar
GSR/ITR/B20 all have the same flow rate. (use one of these)
LS has the lowest flow rate. (dont use this one)
EDIT: Sorry, I was referring to oil pumps.
[Modified by Jeff C, 1:53 AM 12/8/2002]
Old Dec 7, 2002 | 09:31 PM
TREVER's Avatar
Default Re: Which pump for ls/VTEC (Jeff C)
ls waterpumps make more power than vtec pumps do
Old Dec 8, 2002 | 10:15 AM
Default Re: Which pump for ls/VTEC (TREVER)
So and ls/vtec setup with a ls water pump will make more horses or flow more water?
Old Dec 8, 2002 | 02:36 PM
TREVER's Avatar
A ls pump takes less hp to spin. but it flows less. I have had one for over a year now with no overheating problems. Ran ac going uphill in 100 degree plus heat too.
Old Dec 8, 2002 | 03:23 PM
ill phil's Avatar
So Trever an LS water pump and belt will work fine with an Ls/vtec? No overheating problems or other related problems?
Old Dec 8, 2002 | 03:53 PM
TREVER's Avatar
Default Re: Which pump for ls/VTEC (ill phil)
I used a gsr belt and I slotted the tensioner
stevenDAtegra
Dec 15, 2008 07:53 AM
WhiteEJCoupe
Sep 15, 2006 11:41 PM
civicswap
Mar 5, 2005 04:04 PM
bens_redeg
Jul 10, 2004 07:11 AM
GRIMEY.STREET.RACER
Jul 20, 2002 05:02 PM
