Slicks Question
Old Dec 5, 2002 | 04:40 PM
EgSick's Avatar
Default Slicks Question
hi i have an Eg6 with an H22 motor in it... can someone help me what size slicks are use on my car? size brand whatever please thanks you guys..
Old Dec 5, 2002 | 05:45 PM
b19coupe's Avatar
Default Re: Slicks Question (EgSick)
You might want to try your question in the Drag Racing Forum. Hit up exospeedAMcrx, he knows a bit about slicks.
Old Dec 5, 2002 | 05:55 PM
Kataku2K3's Avatar
Default Re: Slicks Question (b19coupe)
You could probably turn a M&H Racemaster 22x9.5 or 8.5x13... My friend's mildly built CRVTEC/EK runs on the by 9.5's and it still spins them a bit... He's got them mounted on Bogart Pro4's... His best is a 12.62@107
Old Dec 5, 2002 | 08:17 PM
ExospeedAMcrx's Avatar
with a stock h22, you would be fine with the 22x8x13. those will be perfect for that HP. you'll be fine up until 250HP or so. some have experience with spinning even at lower HP. but that doesnt mean its the slick size is wrong. you have to play with tire pressure setting and your launching RPM's. once you get the right combo, you'll feel slicks will be the best investment you ever do to your race car.
Old Dec 6, 2002 | 04:34 AM
EgSick's Avatar
Default Re: Slicks Question (exospeedAMcrx)
i have a H22 Turbo in a EG6... tell me what do you think is best. thanks
Old Dec 6, 2002 | 09:54 AM
Kataku2K3's Avatar
If it's a built motor boostin say 10+lbs... I would run MT 24.5x9x13's..... They seem to work well on my friends GSR turbo EK's.... One is boosting 13lbs. generating ~350whp and the other is on 22psi and it pushes 505hp to the ground... Latez
88h22_CRX
Apr 4, 2013 08:55 PM
egjdmcivichatch
Aug 12, 2011 11:18 PM
ESP.net
Feb 5, 2008 04:14 PM
yellowhonda88
Jun 7, 2005 05:56 AM
crxh22a4
Feb 15, 2005 10:19 AM
