valve adj. with gears
Old Dec 5, 2002 | 09:04 AM
1bad-eg's Avatar
Default valve adj. with gears
what's goin on everybody. I have an ls/vtec with a few mods and my question is when I adjust my valves do I do them with the cam gears set at their setting or do I set the gears back to 0 and then adjust my valves?
Old Dec 5, 2002 | 09:47 AM
337 GTI 1.8t's Avatar
Default Re: valve adj. with gears (1bad-eg)
Some adj. gears are designed so you can eye it up and accurately align the cam gear correctly even if its if advanced or retarded...Since you are inexperienced doing it this way and I don't know what type of gears you are using, put them back to 0 degrees and do the adjustments accordingly...
Old Dec 5, 2002 | 12:05 PM
Desslok's Avatar
Default Re: valve adj. with gears (GTI 1.8t)
The small amount you have them adjusted is half of that at the crank, so realistically it is only going to be 1 or 2 degrees off. When your trying to get it at TDC, I can never get it closer than a few degrees off anyways. If you are worried about 1 or 2 degrees, you are much better than I am at lining up the marks.
Old Dec 5, 2002 | 12:30 PM
Tweakmeister's Avatar
adjust them as they sit, already tuned.
Old Dec 9, 2002 | 04:46 AM
1bad-eg's Avatar
Default Re: valve adj. with gears (Tweakmeister)
thanks tweak
CPR
Jan 20, 2006 09:06 PM
Gump
Sep 20, 2004 03:09 PM
MattD@Stoptech
Apr 9, 2004 07:26 AM
91integraLSVTEC
Aug 22, 2003 08:54 PM
Comptech98GSR
Aug 2, 2002 12:28 AM
