radiator fluid
50/50 should be fine. I'd recommend using purified/distilled water if accessable at time. your radiator should take the whole bottle from the auto store. If you don't want to mix, go to honda and get the type 2 coolant that has it mixed in distilled water 50/50 for you to use. You should use honda coolant if you can get it easily enough. have fun alex
thomas
thomas
I just changed my coolant w/ honda type 2 (50/50 premixed) and the car took 5 qts. My coolant ran $27 for 2 gallons.
Hope your Honda dealer doesn't rip you off quite as bad.
You will need 2 gallons of the premixed or 1 gallon of the type 1 coolant and 1 gallon of distilled water to mix with it.
good luck.
Hope your Honda dealer doesn't rip you off quite as bad.You will need 2 gallons of the premixed or 1 gallon of the type 1 coolant and 1 gallon of distilled water to mix with it.
good luck.
you sure u use the whole gallon?
I used premixed(type 2), so I needed 2 gallons of the stuff to get the required 5qts.
I used 1 complete gallon and a part of the second.
y0, riceboi, let me know when your doing this. I need to do mine soon and I can learn from j00
)thanks guys for the help
alex, I can see it now, late night AIM convo, of something that went wrong and you need help
just messing, good luck, let me know if you need some help.
haha i have a feeling it's going to rain on me and i'd have to put everything back together again asap
this time, that damn mount is coming out!
i plan on doing mine this weekend..but call me up when you do yours and i'll help you out(if mine goes smoothly
What about when you want to flush the coolant from the block also. How much more do you need to add?
dennis was just hated on by some ***** *** mod
