13 second prelude
Old Dec 4, 2002 | 11:38 PM
NZ Vtec Weapon's Avatar
Default 13 second prelude
Im in New Zealand,ive got the currently fastest N/A lude in upper north island,its doing 14.508 on 1/4 mile,(proberly slow for you guys,but our fastest N/A in NZ is a 12.2,and fastest turbo Vtec(in austrilasia is a 10.1sec) anyway,i do my time,with full interior(power steer ,Air con etc) i have enlarged throttle body,9.3mm leads,lightened flywheel,lightend under crank pully,high flow air filter+cold air intake,exshast(not extractors) + racing seat,what other kinda mods will see me do a 13 pass?(13.99) cheers,booBAA
Old Dec 5, 2002 | 12:32 AM
Mike95lude's Avatar
Default Re: 13 second prelude (NZ Vtec Weapon)
Try running open header and slicks, and don't run "full interior" . Otherwise, internal work and dyno tuning.
Old Dec 6, 2002 | 03:04 PM
Default Re: 13 second prelude (Mike95lude)
open header??+ u dont get much of an increase by strippin it,its only plastic+foam
Old Dec 6, 2002 | 03:49 PM
Archidictus's Avatar
Unceasing Measure
Actually, you get an incredible improvement when you strip your car. All that foam and plastic weighs a lot when you add it up. There are also seats, mats, interior trim, sound components, dash, etc. If you're serious about breaking 13's, strip your car like a cheap *****, drop your exhaust from the header-back, get some slicks and run octane booster. I'm sure you'll make it happen.
edit: spelling, grrrrr...
[Modified by Archidictus, 7:50 PM 12/6/2002]
Old Dec 6, 2002 | 07:06 PM
Default Re: 13 second prelude (Archidictus)
this is true,BUT im trying to do it with full interior+ive got 225's on which helps greatly+im pretty sure theres a track official who has a wine if you take exhast off(too loud ) ,what are more mods???? thinking along the lines off msd ignition coil/comp+cams,cam gears........
Old Dec 6, 2002 | 10:38 PM
96dc2's Avatar
...run octane booster...
octane booster is bad. causes carbon buildup on valves and other bad things.
Old Dec 6, 2002 | 10:43 PM
Goldfingiz's Avatar
Open header?! He'll lose all his torque...and power in general for that matter. I don't know about you guys, but when my friend ran open header on his way to Meineke to get something welded, the car was a dog
Goldfingiz
Old Dec 6, 2002 | 10:57 PM
96dc2's Avatar
Default Re: 13 second prelude (Goldfingiz)
Goldfingiz
yeah you'll lose most of your lowend, but usually gain top end. and in dragging you don't need lowend, except in 1st gear. if running open header you'll see a bit more gain from adding a 2 ft pipe after the header to induce scavenging effect.
Old Dec 6, 2002 | 11:36 PM
SuperSH's Avatar
Default Re: 13 second prelude (96dc2)
Where exactly did you hear/ find this tidbit of info? SO, basicly you saying because I run higer octane (93) im going to have carbon build up? Do you know where carbon build up comes from ? Thats right, normal every day combustion. Go figure. Hell my car runs so rich I probably have a half of an inch of carbon build up on my pistons by now since I have been running 93 octane for so long. Im sure if you use the $1.99 bottle of octane booster in your fuel it wont be the best for it.
Haha whatever you want to think is good enough for you.
Old Dec 7, 2002 | 12:12 AM
str8rcn's Avatar
Default Re: 13 second prelude (SuperSH)
Try a head package.I dont know of any shops in NZ but we have plenty you could ship to in the US.Are there any good job openings in NZ i always wanted to move there.Oh yeah i did hit 13's w mine with all the boly ons and a gude head package with slicks and no pass seat,jack or spare.
[Modified by str8rcn, 1:13 AM 12/7/2002]
Old Dec 7, 2002 | 11:35 PM
96dc2's Avatar
i didn't say higher octane. i said octane boost. there is a difference. do you know what's in octane boost? neither do i. it's not regulated by any organization so they could just take a **** in there and sell you a bottle. but pump gas IS regulated. a higher octane just reduces the risk of detonation. and yes it will give you more power if your setup deems a higher octane necessary. say if you have a stock LS then it's not worth wasting money on the good stuff.
more info is here: great gasoline debate
Old Dec 15, 2002 | 07:36 PM
Hay str8rcn, what bolt ons did u have?+ what head work???? what was the 13?(13.6 etc...?) cheers
Old Dec 16, 2002 | 03:44 AM
ryanstev's Avatar
You mean Auckland, or further up?
I've got the fastest Prelude from Kaitaia up.
Old Dec 16, 2002 | 04:58 AM
b19coupe's Avatar
Try running open header and slicks, and don't run "full interior" <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emwink.gif" BORDER="0"> . Otherwise, internal work and dyno tuning.
If you don't want to strip the interior, go with the internal work and tuning.
What is your budget? If you have big bucks to spend, sleeve the motor and run big bores, and slap some high compression pistons in there (12-13:1). Get the head ported by a pro and get yourself some big cams.A big header with a 2 1/2 " collector and a 2 1/2" exhaust. Get a standalone and tune, tune, tune. Add some lightweight drag racing wheels and slicks and you should hit 13's no problem.
Old Dec 16, 2002 | 11:36 PM
Default Re: 13 second prelude (b19coupe)
got exhast already,headers arnt to bad+what kinda cams+sleeves????
Old Dec 17, 2002 | 12:45 AM
Goldfingiz's Avatar
Open header?! He'll lose all his torque...and power in general for that matter. I don't know about you guys, but when my friend ran open header on his way to Meineke to get something welded, the car was a dog <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emthdown.gif" BORDER="0">
Goldfingiz
Really? I wasn't aware of that...yeah he was shifting very low, so that explainsi t...
Goldfingiz
vietdoughboy
Oct 25, 2007 06:14 PM
Lip
46
Sep 20, 2004 07:20 AM
Slam168
Apr 2, 2004 05:14 PM
gmsu00
Sep 3, 2001 05:16 AM
