best spark plugs and wires??
Old Dec 4, 2002 | 08:38 PM
blulude92's Avatar
Default best spark plugs and wires??
just wondering which ones are the best. what kind of differences might i notice?? any more power?? i got a JDM H22A with about 38,000 miles on it. thanx for the help!
Old Dec 4, 2002 | 08:41 PM
Quiklude's Avatar
Default Re: best spark plugs and wires?? (blulude92)
i'd stick with ngk-r's, ngk wires are good too, im running magna core they seem to work alright...
Old Dec 5, 2002 | 07:53 PM
ELUD THS's Avatar
New User
Default Re: best spark plugs and wires?? (Quiklude)
agree ive always had NGK's and never had a problem.
Old Dec 5, 2002 | 08:58 PM
Furry
Guest
Posts: n/a
Default Re: best spark plugs and wires?? (ELUD THS)
wires are wires....... get the cheap ones and replace em every 15k miles.....
as for plugs, i use NGK zfr7f-11, they are 1.99...... i replace those every 6-10k miles
Old Dec 5, 2002 | 09:24 PM
Import RP's Avatar
Default Re: best spark plugs and wires?? (Furry)
Get these:
http://www.groupbuycenter.com/buy.aspx?id=7607
Thats a realllly good deal!
Old Dec 5, 2002 | 11:11 PM
drift's Avatar
New User
Default Re: best spark plugs and wires?? (Pyrochaos38)
Magnecor 8mm wires and NGK Iridium plugs.
i pull my plugs and brush them off every 20,000 miles or so.
Old Dec 6, 2002 | 03:37 AM
BoYgUaN's Avatar
Default Re: best spark plugs and wires?? (drift)
zfr7-11 are colder than stock plugs
if i remember stock is 6-11
Old Dec 6, 2002 | 07:05 AM
rjr162's Avatar
Default Re: best spark plugs and wires?? (-743-)
denso, ngk is played out
the denso iridium's are pretty phat.
Old Dec 6, 2002 | 09:23 AM
DsITR's Avatar
amen....wires do little to nothing..0 power gains IMO...just need to change your plugs..I am happy w/any NGK plug so far
DO NOT buy Bosch Platinum +4, they do not work well in hondas for some reaseon/
Old Dec 6, 2002 | 09:38 AM
tec-9-7's Avatar
Default Re: best spark plugs and wires?? (dsludefosho)
Magnecor 8mm have a good reputation, as do Honda OEM wires.
Paul
Old Dec 6, 2002 | 07:19 PM
user 9782082308's Avatar
Default Re: best spark plugs and wires?? (tec-9-7)
NGK is played out??? Thats like saying synthetic oil is played out.
Hondas were built with NGKs. As an enthusiast its hard to argue with engineers. If you see gains from plugs or wires on an NA setup, then your previous parts were faulty.
Old Dec 13, 2002 | 02:13 PM
thatchmaster's Avatar
New User
90% sure honda OEM wires are NGK anyway. I replaced my stock ones around 70k, and I've been using ngk copper plugs (pretty sure they're zfr6f-11's). I've had no problem with them, and i change them about every 10k. Pretty sure the OEM replacements are pzfr6f-11's (p for platinum) ... but at $16 a pop, it's not too worth it, when I'm blowing by oil from the oil control rings and they get coated in 10-15k. The main difference w/ platinum, is the fact that they will last longer, around 60k. And 100k for iridium. One thing... don't gap platinum/iriduim.. they should be pregapped. You'll wear off the platinum/iriduim if you do... well, some of it at least.
Wires.. I have ngk blues.
Hope that stuff learns someone sompthin'
-Erik
courtney42
25
Mar 6, 2009 12:05 AM
sLo h22
Mar 11, 2006 10:47 AM
lude98SH
Aug 30, 2005 05:50 PM
Got Spoool
26
Jun 13, 2003 03:06 PM
crookedletterd
Jul 29, 2001 08:40 PM
