Timing belt harmonics....
Old Dec 4, 2002 | 07:38 PM
migs's Avatar
Default Timing belt harmonics....
Im having some issues revving 500rpm before cutoff. Everytime I wind up, I hear a "SHHHHHH" sound from the timing belt side. It sounds like something is vibrating. No power loss. I have NO heat shields either.
Valves are properly adjusted, compression check is okay.
Somebody had told me it might be the harmonics from the timing belt. The belt has approx 70K on it. Is it time for a new belt. BTW this sound has been going on for the past 30k miles.
TIA
migs
[Modified by Migs, 10:39 PM 12/4/2002]
Old Dec 4, 2002 | 11:07 PM
ILLTEGRA
Guest
Posts: n/a
Default Re: Timing belt harmonics.... (Migs)
i had that problem with my mustang gt car is ****
and it had the same problem , i sprayed in between the belt and the gear with some "belt lubrication" while the engine was on
and the sound went away.
Old Dec 5, 2002 | 12:40 PM
migs's Avatar
Default Re: Timing belt harmonics.... (ILLTEGRA)
Anybody else have feedback on this?
Old Dec 5, 2002 | 12:43 PM
ZygSpeed's Avatar
70K miles!
Change that bad boy ASAP, especially if you're exercising the car.
Have you checked the belt tension or deflection?
[Modified by Zygspeed, 4:44 PM 12/5/2002]
Old Dec 5, 2002 | 12:47 PM
migs's Avatar
Default Re: Timing belt harmonics.... (Zygspeed)
Havent.... a mechanic informed me of buying a new tensioner, water pump, etc. Is he shooting me straight?
Old Dec 5, 2002 | 12:48 PM
BlueR's Avatar
pretty straight...
might as well replaced those things when you replace the timing belt
everything is located right there...saves you labor charges
Old Dec 5, 2002 | 12:50 PM
ZygSpeed's Avatar
I put a new tensioner on at 85K miles just for peace of mind when I changed the timing belt.
If the water pump isn't leaking then I wouldn't change it (I didn't and it was still fine @ 125K a couple weeks ago).
Better safe than sorry, especially when goofing off.
Old Dec 5, 2002 | 12:51 PM
TsunamiZC's Avatar
once it gets time to change your timing belt when your getting close to 100k ...its a good idea to get a new tensioner ...water pump ..etc .......and yes ....change that belt
Old Dec 5, 2002 | 01:28 PM
B2FiNiTY's Avatar
Do that tuneup Better safe than sorry man.
JDMtype Eg6
Feb 18, 2007 05:45 AM
ham
Aug 2, 2005 05:17 PM
94gsr_vtc
Nov 12, 2004 08:30 AM
rybred
Dec 7, 2002 09:58 PM
nerdish
Jul 17, 2001 11:22 PM
