Block guard: Waist of money?
Old Dec 4, 2002 | 07:15 PM
InfamousRS's Avatar
Default Block guard: Waist of money?
Im considering a STR block gaurd for my B20B with stock sleeves.
Its seems that I have read severl stories latly that people are still cracking sleeves with a block gaurd.
Im planning on 10 psi with my B20 (hondata and injectors of coarse)
Is the block gaurd just a wist of $114.99?
Old Dec 4, 2002 | 07:36 PM
TypeC's Avatar
Default Re: Block guard: Waist of money? (InfamousRS)
Waist of money?
I don't think you wear it. Could be wrong
But yeah, I'd get some rods or pistons before a BG.
Old Dec 4, 2002 | 08:08 PM
Etylorcen's Avatar
Default Re: Block guard: Waist of money? (Blade TypeC)
No one is going to give you a definate answer. Some say its definately worth it and it doesnt cost much money, other say it is a WASTE becaues it blocks the coolant flow to the upper part of the cylinders. Just do a search and make up your opinion for yourself.
Old Dec 4, 2002 | 08:10 PM
BoM's Avatar
BoM
Default Re: Block guard: Waist of money? (Etylorcen)
its worth it if your building your block, but using stock sleeves. better than nothign at all.
Old Dec 4, 2002 | 10:42 PM
turbopanda's Avatar
Default Re: Block guard: Waist of money? (BoM)
blockguard =
used them on two honda engines that i've turbocharged (D16Y8 and B18C), and never broke/cracked a sleeve. About to use one on my third engine, a B20B.
make sure though that if you get a blockguard for your b20b that the holes in the gasket match up with holes on the blockguard, or else you will definately have overheating problems.
also, if you can, try and get a blockguard that looks like mine.. remember that b20b sleeves usually crack where the cylinders join up. most blockguards don't go to that point of the sleeve, but I had mine made so that it does to help with strength in that area, but at the sacrifice of a smaller than normal water hole. i'm not using a stock radiator, and i have lots of big fans on it, so i should be okay.
https://honda-tech.com/zerothread?id=331680
Old Dec 5, 2002 | 03:32 AM
420aNT's Avatar
Default Re: Block guard: Waist of money? (turbopanda)
junk
Old Dec 5, 2002 | 05:38 AM
tk's Avatar
tk
Default Re: Block guard: Waist of money? (18gTeg)
IMO its bad detonation that does the damage not the block guard
Detonation is an engine worst nightmare.
Tuning is the key to prolong engine life
But for turbo applications I sleeve the blocks with darton t-top sleeves.
I have a customer that boosted 35psi all summer and still ticking
We will still tear it down and refresh just for safety wise.
[Modified by tk, 9:38 AM 12/5/2002]
BobbyRodriguez
Nov 11, 2011 06:57 PM
TDogg Teg
May 15, 2008 09:34 AM
Targa4Life
Apr 7, 2005 11:07 AM
CIVICNONVTEC
Aug 23, 2003 06:00 AM
madman604
May 23, 2003 04:19 PM
