wiring vtec on obd1 pr3
Old Dec 4, 2002 | 06:31 PM
iwhichisme's Avatar
Default wiring vtec on obd1 pr3
My friend says he has an ob1 pr3 ecu, which ive never seen before,nor worked with. I was wandering if anybody new how to wire the vtec oil pressure, and solenoid. It is in a 94 civic lx. So if anybody could give me a link to a site, or share some info which wires goe where. There are only three wires, one of them which is the ground. Just need know where the 2 vtec wires go on the ecu.
thanx
chazz
Old Dec 4, 2002 | 07:17 PM
itrSteez's Avatar
Default Re: wiring vtec on obd1 pr3 (iwhichisme)
pr3's are non obd... it's the one you get with Sir swaps
Old Dec 4, 2002 | 11:17 PM
Kataku2K3's Avatar
Default Re: wiring vtec on obd1 pr3 (prawjEKt Cx)
Yea the PR3 is non OBD... If you still need the pinouts this is what they are.... The pin for the VTEC solenoid is A8, B5 for the VTEC pressure, B19 for the KS, and C8 for the secondary oxygen sensor.... To run that ECU you'll need the nonOBD-OBD1 harness converter, injector resistor box, and the non OBD distributor... I would really just look into running a chipped P28 or P30 tho.... These are both OBD1 ECU's.... Latez
Old Dec 5, 2002 | 11:01 AM
nsxmatt's Avatar
Default Re: wiring vtec on obd1 pr3 (JDMspecEG6)
There is a OBD 1 Pr3. I know cause i'm running it. It's from a 92-93 JDM integra XSi with the obd1 B16. It is the same as a p30.
Old Dec 5, 2002 | 01:51 PM
Kataku2K3's Avatar
Default Re: wiring vtec on obd1 pr3 (nsxmatt)
Really i didn't know the Xsi used a PR3... my bad... I guess you learn something new everyday... Latez
Old Dec 5, 2002 | 02:04 PM
NiiS's Avatar
Old Dec 5, 2002 | 02:55 PM
tinkerbell's Avatar
i am running an Xsi PR3 ECU, i think it is non-OBD type from 1991...
is this right?
anyways - here is the complete pin-outs for it,
http://www.geocities.com/b16aprelude/hondaengines.html
HTH,
t..
Old Dec 5, 2002 | 03:16 PM
nsxmatt's Avatar
Default Re: wiring vtec on obd1 pr3 (tinkerbell)
There is a obd 0 pr3 found on the pre-obd teg XSi's and in 92 they went obd-1 and the xsi went with a obd-1 pr3 ecu.
Old Dec 5, 2002 | 03:18 PM
tinkerbell's Avatar
thanks, that is what i had supposed
t..
Old Dec 5, 2002 | 09:03 PM
itrSteez's Avatar
well i'll be dammed, i figured they woulda changed the code when they went obd1, looks like i'm wrong, it happens alot
SingleCamin
Mar 5, 2009 11:57 PM
TMC_EF
Jan 24, 2009 05:12 AM
.M.
Jul 13, 2005 10:54 PM
iwhichisme
Dec 4, 2002 06:33 PM
Jefe06
Oct 3, 2001 07:47 PM
