head gasket !!or something else???
Old Dec 4, 2002 | 02:11 PM
FLIPboi's Avatar
Default head gasket !!or something else???
i have a civic hatch with a 98 ls swap , and when i put it in after htat my car wus smokin alil but then after a while i blew my head gasket then thier wuz madd smoke i couldent see the roade behind me and my boys behined me cold not see the road , becuse of all the smoke , so i replaced the head jasket and now its still smokin alil like it wuz when i put the motor in , i though it wus the pistion reings so i did a compression test and it passed , and now i donno what to do im stuck , so can any one help ..how do i get rid of the smoke ?????
Old Dec 4, 2002 | 02:17 PM
Kataku2K3's Avatar
Default Re: head gasket !!or something else??? (FLIPboi)
Check valve guides??? I would leakdown test the motor first... If you get air comin through the PCV system then you most likely have bad rings (since your compression test turned out okay i'm sure they're fine) If you get air comin through the intake manifold or exhaust manifold then you got a bent valve (again this is probably not going to have anything to do with oil) coolant bubbles then your head gasket is most likely blown... I'm sure everything there should check out fine but i would check your PCV valve.... If everything else is fine then I'm pretty sure that's what your problem is... Without a properly working PCV valve your motor is free to drink all the oil it wants... It just sucks it through your PCV box up the tube to the manifold and into your motor... Good Luck and i hope this helps... Latez
Old Dec 4, 2002 | 02:22 PM
FLIPboi's Avatar
Default Re: head gasket !!or something else??? (JDMspecEG6)
thank man ill go do a leak down test and get a new valve , but i hope its the valve cuz i dont feel like taking my head off agian , i juss got it back on today ..thanx man !!
Old Dec 4, 2002 | 03:25 PM
Quik Chris's Avatar
Do a compression test to see if its the rings, do a leak down to test the valve seals, guides.
Did you do the head gasket yourself? If you did, then did you go about it correctly? If you didn't follow the head stud removal/install process correctly, then there's a good chance the head didn't seal on the block... or even worse it warped the head.
Did you get all the oil out of your coolant when your gasket blew? If you did, check to see if there's oil in your coolant again. If not,
Does the car still overheat?
shm91
Sep 1, 2013 03:56 AM
GSR936
Apr 28, 2009 06:10 PM
boostedjdmdc2
Jan 13, 2009 10:49 AM
TegraD
Nov 9, 2008 01:49 PM
zcmotor
29
Apr 18, 2008 10:20 AM
