98 spec itr 4-1 headers in a 90-93 integ?
Its not the subframe you have to worry about, its the front crossmember. Some people bang them forward a bit to make the header fit but that weakens the crossmember or you can buy an aftermarket one...
You would have to notch the crossmember like this or maybe a little bit more...
You would also have to remove the bar that bolts on to the crossmember and the firewall. 92-93 GSRs do not have that bar. That's about it.
[Modified by jonsteR, 2:15 PM 12/4/2002]
It fits with the crossmember modification but you will have major ground clearance issues. Mine is smote/dented to hell and I have only had mine a year or so. My car is dropped 2 inches though. It also will potentially make your resonator pipe scrape as well. If you have the money use a SMSP custom header.
[Modified by Honda F1, 5:10 PM 12/4/2002]
... Latez
Yes I am running that header. Sure Honda designed the header awesome. The problem is, it was designed for the DC chassis not the DA. My car is low but not "gangsta" low so its not just my ride height. As far as power is concerned it definately is top notch in that department.
I've heard some people having no problem, but some people having to modify their crossmember to fit the header.
Someone sells traction bar for DA chasis?
Jay Kim
Jay Kim
Place racing also sells a cross member for the DA which would allow you to run the JDM 4-1 header (or same configuration) with no modifications.
Alpha_Omega
Apr 20, 2010 02:49 PM
