98 spec itr 4-1 headers in a 90-93 integ?
Old Dec 3, 2002 | 01:25 AM
SpoonXSi's Avatar
Default 98 spec itr 4-1 headers in a 90-93 integ?
just wanted to know if itr 4-1 headers would fit in a 90-93 integ (da). i heard you would have to cut the front subframe. thanks for the help
Old Dec 3, 2002 | 02:22 PM
GTM's Avatar
GTM
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (SpoonXSi)
You do have to cut the front subframe.
Old Dec 4, 2002 | 12:18 AM
JDMvtecDRAGSTA's Avatar
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (GTM)
so the itr 4-1 headers would fit in the DA chassis with no clearance issues? thanks for the help
Old Dec 4, 2002 | 09:35 AM
Jackson's Avatar
Its not the subframe you have to worry about, its the front crossmember. Some people bang them forward a bit to make the header fit but that weakens the crossmember or you can buy an aftermarket one...
Old Dec 4, 2002 | 01:02 PM
Kataku2K3's Avatar
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (Jackson)
Yea just get a traction bar.... It will clear with a lot of room and the traction bars look a lot cleaner... Peace
Old Dec 4, 2002 | 01:13 PM
jonsteR's Avatar
You would have to notch the crossmember like this or maybe a little bit more...
You would also have to remove the bar that bolts on to the crossmember and the firewall. 92-93 GSRs do not have that bar. That's about it.
[Modified by jonsteR, 2:15 PM 12/4/2002]
Old Dec 4, 2002 | 02:09 PM
Honda F1's Avatar
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (jonsteR)
It fits with the crossmember modification but you will have major ground clearance issues. Mine is smote/dented to hell and I have only had mine a year or so. My car is dropped 2 inches though. It also will potentially make your resonator pipe scrape as well. If you have the money use a SMSP custom header.
[Modified by Honda F1, 5:10 PM 12/4/2002]
Old Dec 4, 2002 | 02:39 PM
Kataku2K3's Avatar
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (Honda F1)
Are you runnin the JDM ITR header??? Just wondering cuz Honda designed that thing awesome... The runners sit more diagonal then a convetional DC 4-1 or something so it keeps the runners up a lot higher than normal... I hate DC's for that very reason but the JDM ITR is my favorite ... Latez
Old Dec 4, 2002 | 10:36 PM
Honda F1's Avatar
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (JDMspecEG6)
Yes I am running that header. Sure Honda designed the header awesome. The problem is, it was designed for the DC chassis not the DA. My car is low but not "gangsta" low so its not just my ride height. As far as power is concerned it definately is top notch in that department.
Old Dec 4, 2002 | 11:08 PM
Kataku2K3's Avatar
Yea i know what ur sayin... That's cool... Latez
Old Dec 4, 2002 | 11:14 PM
Norcalstoppy's Avatar
I've heard some people having no problem, but some people having to modify their crossmember to fit the header.
Someone sells traction bar for DA chasis?
Jay Kim
Old Dec 4, 2002 | 11:16 PM
Honda F1's Avatar
Default Re: 98 spec itr 4-1 headers in a 90-93 integ? (AllMotorMonster)
Trust me if you have a 90-93 Integra you must modify the crossmember.
Old Dec 5, 2002 | 09:26 AM
jonsteR's Avatar
Place racing also sells a cross member for the DA which would allow you to run the JDM 4-1 header (or same configuration) with no modifications.
tougel
Oct 16, 2010 09:21 AM
Alpha_Omega
Apr 20, 2010 02:49 PM
()0()Miklo
Aug 5, 2007 11:57 AM
springthemadcap
11
Apr 18, 2007 06:18 PM
BXk24ek9
Apr 4, 2007 04:03 AM
