if i do an obd2-1 conversion with p28 obd1 then do i need the o2 sensor in the cat???
as long as you have one O2 sensor thats near the down pip where it connects with the cat part then you should be fine.
I currently have 16a2 with obd2-1 jumper and I'm using a stock p28. Car is running but when you try to drive it the engine bogs hard at around 4k rpm.. currently the o2 sensor is in the header but NOT in the cat which is ok since i'm running an obd1 ecu correct? or is this my problem? Can't seem to figure out what else it could be... The car engine gives even less throttle response after its been running for a few mins.. cool it down and then its ok again but boggs.. any help?
Just thought of something.. could this be caused by using the wrong obd injector clip? I am running obd1 ecu so i need obd1 clips right? or will obd2 work too?
Here is a photo showing you where J1 is, it's circled. Look on the PCB and you will see it labeled, right above R54.
good luck.
good luck.
Laserjock
Apr 16, 2005 09:50 PM
