What ecu code makes you run lean?
Old Dec 2, 2002 | 03:49 PM
1tyme's Avatar
Default What ecu code makes you run lean?
does a 1 make u run lean? my fren told me so. i just wanted to know cuz i'm running turbo and lean is not good for turbo. oh and i have a p28 ecu.
Old Dec 2, 2002 | 03:53 PM
Kataku2K3's Avatar
Default Re: What ecu code makes you run lean? (1tyme)
A code 1 doesn't really mean that you are running lean rather there is something wrong with your oxygen sensor or it's wiring...
Old Dec 2, 2002 | 05:30 PM
hondaeg5's Avatar
Default Re: What ecu code makes you run lean? (JDMspecEG6)
if the o2 sensor didnt see a signal(code 1), than wouldnt it run rich? maybee im wrong?
Old Dec 2, 2002 | 06:35 PM
1tyme's Avatar
or does any anycode make you run lean? i'm also throwing a code 9 (TDC of cyl #1) i doubt that will make me run lean but i don't know for sure. 99% sure though.
[Modified by 1tyme, 3:36 AM 12/3/2002]
nk2k2
Jan 12, 2007 12:44 PM
i64X
Feb 18, 2006 01:23 PM
520_Motorsports
Aug 10, 2004 10:51 AM
Ricey McRicerton
Aug 28, 2003 01:45 PM
