fiberglass questions
Old Dec 2, 2002 | 08:12 AM
bboyprelude's Avatar
Default fiberglass questions
how many layers should be used when doing interior stuff such as doors and speaker boxes
where can i get fiberglass sheets
is the spray better than the sheets
is there a website so i can shut up now?
Old Dec 2, 2002 | 01:44 PM
skoolnu's Avatar
Default Re: fiberglass questions (bboyprelude)
When i make a speaker box outta fiberglass, i take some cloth and streach it out over the whole spot and resin that... then after put about 5 layers of fiberglass colth over that. let it dry do your body work and sand like a motha. And where to get your fiberglass mat and resin and all that.... your local body shop supply store should have everything you need.... the spray sucks. good luck.. and hope you have some time ahead of you, cause its a long process.
Chris Burkhart
Syracuse, NY
Old Dec 2, 2002 | 02:41 PM
tnbigdawg's Avatar
Default Re: fiberglass questions (skoolnu)
hand laid fiberglass is way better that sprayed...because spraying can cause air bubbles...imagine those rattling when you bump your music. hand laid, if done properly can get rid of these air pockets because you are in control by squeezing them out.
a tip: only laminate a few layers of fiberglass between drying times, this way you can prevent excessive heat buildup causing warpage.
Old Dec 2, 2002 | 05:07 PM
Default Re: fiberglass questions (tnbigdawg)
thanks a lot for you guys' help. yeah i have all this summer. i hope to totally redo my car interior. everything from custom door panels to dash to center console to a panasonic gamecube with wavebird controllers. wish me luck.
if you don't know what a panasonic gamecube is... look up "panasonic gamecube" on ebay. everybody should have one of these in their car. good one i already got one, "ouch!"- my wallet
btw its a 92 prelude si
i'll post some pics of the design sketches when i get around to it
Turbocivic94
Feb 16, 2016 04:00 PM
Dontoh
Paint and Body
17
Jan 1, 2011 01:42 PM
gdrum
Paint and Body
Apr 19, 2010 06:35 AM
SlammedEG6
Paint and Body
15
Jan 31, 2010 10:12 AM
infamouskillas
Paint and Body
Jun 16, 2008 09:37 PM
