guage installation
Old Dec 2, 2002 | 06:26 AM
Scary1109's Avatar
Default guage installation
I want to put an oil pressure and a water temperature guage on my gsr. i would like to use the electrical autometer guages. has anyone done this? and is there a problem with using the electrical guages? is the install difficult?
Thanks
Scary
Old Dec 2, 2002 | 06:31 AM
Crazydave's Avatar
Default Re: guage installation (Scary1109)
installation is pretty easy.. just make sure to ground the sending units..
you will need to run a line of the block for the oil pressure
you need a BSP to NPT adapter to make this work
you dont want the sending unit hanging of the block.
Old Dec 2, 2002 | 08:23 AM
Scary1109's Avatar
Default Re: guage installation (Crazydave)
so i need to tap the block for the oil pressure guage?
Old Dec 3, 2002 | 03:41 PM
Scary1109's Avatar
TTT, does anyone know anymore bout this?
Thanks
Scott
Old Dec 3, 2002 | 03:55 PM
Kataku2K3's Avatar
Yea all you gotta do is "T" it from the stock oil pressure sender on the back of the block.... I personally like the electronic senders over running a line into the cabin of your car with oil pressure in it to a mechanical gauge... Good Luck
afplayboy17
Oct 6, 2007 10:39 AM
Drag-Accord
Aug 11, 2004 08:13 AM
Proper
Aug 8, 2002 10:56 AM
Petah
19
May 6, 2002 05:41 AM
NeXtLeVeL_TyPe_R
Oct 2, 2001 09:50 PM
