should i go LS/Vtec or get another b18c R?
well my baby was stolen a couple weeks back, they toke the engine
now i'm debateing on what i should put in, show i go with the same set up as i had before jdm b18c R(mods are in sig) or go with a LS/Vtec, bored b18a block to 2.0, crower rods, je pistons, gsr head, etc. no turbo, cause i want an all motor setup....well what do you guys think? which one is faster by the way?
I like my ls/vtec setup it runs hard and with that 2.0 ls/vtec that you want that should run nice but if you go 2.o are you gonna sleeve the block?
no it was crate packages nor was the car fixed up already. cause i wanted stronger internals thats why i changed the pistons.
If you do the ls/vtec do it right or you will regret it . My friend sure did. Dumb *** tried to rev it to 9500 with a stock bottom end.
I ll tell you first hand that building an ls/vtec is a pain in the *** and a lot of work!
But is defeinetly well worth it!
If you want to take the easy way out and probally cheaper way out go with the b18c R
-BRian
-BRian
