how do i remove bondo?????
Old Dec 1, 2002 | 10:56 PM
I_love_my_Crx's Avatar
Default how do i remove bondo?????
just like it says...i had some one do my moldings and they did a shitty job so i want to know if i can take it off...thanks
Old Dec 2, 2002 | 01:49 PM
skoolnu's Avatar
Default Re: how do i remove bondo????? (I_love_my_Crx)
you sand the ****... i hope there is a welded piece of steel behind all that filler. cause if there is not you will need to weld in plate to shave the molding, then do your body work with filler. IM me if you need more help.
Old Dec 2, 2002 | 02:09 PM
GOKOOL Mike's Avatar
yeah sandpaper
Old Dec 2, 2002 | 02:22 PM
tnbigdawg's Avatar
Default Re: how do i remove bondo????? (Lance Burkhart)
if you're gonna redo it, you can use a propane torch to heat it, and chisle it away. if you havent before, weld sheetmetal so that there isnt too much filler on there or else it can crack.
Old Dec 3, 2002 | 07:57 AM
i dont really care if it cracks falls off or anything....i just want it off because i have the ww rs kit for my car and i want the side skirts to fit into the sides...thanks for the help...
Old Dec 3, 2002 | 01:03 PM
h23vtec_dc2's Avatar
use a DA sander..(sand disc-air sander). thats if you have a compressor. go to harbor freight
Old Dec 3, 2002 | 03:18 PM
tnbigdawg's Avatar
Default Re: how do i remove bondo????? (mugenb18c5)
Just to let you know, DA stands for "dual action" sander.
Old Dec 3, 2002 | 03:27 PM
ef civic's Avatar
Default Re: how do i remove bondo????? (tnbigdawg)
i had the same prob the fastest way is to use a grinder and grind the bondo off did both sides in 20 minutes but wear a dust masks and don't do it in a garage my garage was filled with powder lol
Old Dec 3, 2002 | 06:03 PM
sleeprhatch's Avatar
Default Re: how do i remove bondo????? (ef civic)
pry bar
Old Dec 4, 2002 | 01:28 AM
iam7head's Avatar
Default Re: how do i remove bondo????? (sleeprhatch)
I just kick it..and it crack so easy..Yeah..Cali heat helps too..
Old Dec 6, 2002 | 07:38 AM
thanks for pointing that out.. sand disc air sander is what it says below dual action on the box.
duh702dc2
Paint and Body
May 10, 2014 11:43 AM
buymesomedunks
Paint and Body
12
Apr 23, 2012 06:05 PM
civic_90
May 3, 2009 10:30 AM
godzhand
Jan 2, 2007 07:29 PM
BLUTO
Mar 17, 2003 06:57 PM
