ECU Question???
Old Dec 1, 2002 | 10:48 PM
jdmEKhb's Avatar
Default ECU Question???
Hey I am looking to by a Type R ecu and I want the 98 JDM spec R one, but I dont know the exact ecu codes, right now i have a USDM GSR ecu and the code is 37820-p72-A02, and I know that a 98 USDM type r ecu code is 37820-p73-A03, I also know the 98 JDM spec r ecu is 37820-p73-013, but my question is what year is the ecu of a JDM spec r that has the code 37820-p73-003, because i thought 96-98 were the same but when I looked at my friends ecu out of his JDM Integra Type R he had the 37820-p73-013 and that is how I know that code and that is when i got confused...please try to help me I know this post is a little bit confusing...thanks!!
Old Dec 2, 2002 | 08:24 AM
jdmEKhb's Avatar
Default Re: ECU Question??? (jdmEKhb)
Can anyone help me???
Old Dec 2, 2002 | 08:32 AM
Desslok's Avatar
97-01 should be p73.
Old Dec 2, 2002 | 09:50 AM
Katman's Avatar
ok, well all ITR ecu's, JDM or US are 'P73' ecu's. The best way to really tell apart a JDM vs. US ITR ecu is by plugging simply plugging it into your car. What you want to do is unplug the VTEC pressure switch (green plug on vtec solenoid) -- If you get a check engine light for that unplugged sensor then that will designate a US P73 ecu. All JDM P73 and other OBD2 vtec ecu's do NOT look for that particular sensor, nor a 2nd 02, or CKP sensor's as well.
Old Dec 2, 2002 | 11:04 AM
jdmEKhb's Avatar
Default Re: ECU Question??? (Katman)
ok, sounds good, but I want to know the difference in years of the ecu's, because I know the way to tell apart USDM from JDM is that after the p73 it is either an A..... or a 0....., ex. 98' USDM Type R p73-A03, and 98' JDM Type R p73-013, the thing I need to know is the difference in the numbers after the p73, like p73-???, if its JDM it will start with a 0, but I dont know how to tell the difference in the 96-97 JDM Type R's and the 99+ JDM Type R's, i know one of them is p73-003 but I dont know which exact year that came out of, all I know for sure is the 98' spec, if you know any further info. please let me know...thanks!
Old Dec 2, 2002 | 01:19 PM
b19coupe's Avatar
1997 Type-R=37820-P73-A02
1998 Type-R=37820-P73-A03
2000-01 Type-R=37820-P73-A04
All part numbers are USDM.
Old Dec 2, 2002 | 01:28 PM
Kataku2K3's Avatar
Default Re: ECU Question??? (b19coupe)
So you are saying that the JDM ITR ECU is the same as the USDM????
That's funny Albert when you pulled out Anthony's JDM ITR ECU out of his JDM ITR it didn't start with an P73-"A" just as we expected it was a "0".... As long as we know it's JDM we can tell if it will work in you car albert.... Just needs to run off of A,B,D...
Old Dec 2, 2002 | 01:34 PM
b19coupe's Avatar
Default Re: ECU Question??? (JDMspecEG6)
I was just giving you all the information that I have regarding Type-R ECU's. I don't have any information on JDM stuff. I was hoping that it would give a point of reference and help you out a little.
Old Dec 2, 2002 | 01:55 PM
jdmEKhb's Avatar
yeah thanks a lot, I get the USDM stuff cuz it all start with p73-A.... but it is the JDM stuff that is confusing me????
Old Dec 2, 2002 | 02:14 PM
b19coupe's Avatar
I would hazard to guess that 37820-P73-001 would be the first JDM Type-R ECU (96?) and that subsequent JDM ECU's would be sequentially higher. 002, 003, on up to 013 and beyond.
Old Dec 2, 2002 | 02:47 PM
Nameless RB26's Avatar
JDM Type R ecu's:
37820-p73-003 = 96-97
37820-p73-013 = 98-99
37820-p73-023 = 00-01
Old Dec 2, 2002 | 04:16 PM
jdmEKhb's Avatar
Default Re: ECU Question??? (Nameless)
nameless are u sure thats how JDM ecu's go and there isnt any others just the three???
Old Dec 2, 2002 | 04:24 PM
yes.
Old Dec 2, 2002 | 06:54 PM
jdmEKhb's Avatar
ok but where did you find this out?
Old Dec 2, 2002 | 09:00 PM
Rukkus233's Avatar
try google
Old Dec 2, 2002 | 10:03 PM
Default Re: ECU Question??? (CheddaBob)
I found it out on numerous sites. Back in the day when I was doing nothing but sitting for hours each day researching stuff for my own personal knowledge..
I have also seen pics of each JDM ecu, and I've owned both 97 and 00 JDM ITR ecu's...
Old Dec 11, 2002 | 11:37 PM
jdmEKhb's Avatar
OK well I thought it was all figured out til i talked to a guy the a p73-013 and he said he took it out of a 97 JDM Type R.......so I dunno?
Old Dec 12, 2002 | 07:47 AM
It won't matter if it's a 97 or 98, they are both the same plug style..
Old Dec 12, 2002 | 08:11 AM
HOOKUPS-PRO-CRX's Avatar
jdm itr e.c.u i have 4 on hand if you need one. still reccomend a obd1 p28
Old Dec 12, 2002 | 01:51 PM
jdmEKhb's Avatar
Default Re: ECU Question??? (HOOKUPS-PRO-CRX)
this is true the plugs are the same from 97 to 98 but as u said in your previous post, they are different depending on the barcode
Old Dec 12, 2002 | 01:53 PM
Yah, the codes are different.. but they're the same.
Old Dec 13, 2002 | 10:39 AM
jdmEKhb's Avatar
Well not from my experience with them. The JDM Type R motors have differences thats why the 96-97's only make about 197hp and the 98-99 make about 210! And every time the barcodes change that means that they have been revised so something just be a little different, I mean the main things are the same that you can tell right off the vtec and fuel cuttoff but I think they did make some little changes!
clockwork675
Jun 12, 2010 03:14 PM
Eli Mac 67
Jul 12, 2007 06:07 PM
mhsballplaya2369
Jul 6, 2004 10:45 PM
jdmEKhb
Dec 2, 2002 08:25 AM
b18c-93
Mar 12, 2002 08:58 PM
