question about p28 ecu...
Old Dec 1, 2002 | 10:31 PM
MeanGreenEG9's Avatar
Default question about p28 ecu...
If i have a b16a and i'm using an obd2-1 jumper .. can i use a regular p28 or will i have to get the hondta or get it chipped to make it work right?
Old Dec 1, 2002 | 11:34 PM
SRd240sx's Avatar
Default Re: question about p28 ecu... (Junek9)
Yes the stock p28 will work, but the maps are totally off and also your VTEC engagement will be off along with a lower redline. Basically it will run like SHIAT
Old Dec 2, 2002 | 09:59 AM
Katman's Avatar
You can run the stock P28 ecu to get around....but it's highly suggested to have it reprogrammed to DOHC VTEC spec, as the stock P28 fuel maps aren't sufficient enough for a B-series engine not to mention an early redlind of 7200rpm -- hence the 'shittyness' of using a stock P28 ecu w/a B-series engine. If you need reprogramming services....hit me up or check the link in my signature
nfieldzy12
Apr 12, 2012 12:48 AM
leighton1245
Feb 11, 2008 05:23 PM
crashzerothree
Mar 6, 2006 03:17 PM
Dent Free
Dec 7, 2003 09:27 AM
HOND PWR
Jul 22, 2003 05:44 AM
