exhaust ....bigger...better?
Old Dec 1, 2002 | 10:07 PM
Tiwe's Avatar
Default exhaust ....bigger...better?
is the bigger(diameter) the exhaust (header, b-pipe , muffler) the more power u will gain from it? If its true then why dont ppl make 2.5+" cat-backs ?
Old Dec 1, 2002 | 10:09 PM
Rob :190:'s Avatar
Default Re: exhaust ....bigger...better? (Tiwe)
it's only true to a point, 2.5" is about all you need for most NA setups with a 1.8 liter motor. If you go bigger, or go boost, you might want more that 2.5" piping
Old Dec 1, 2002 | 10:12 PM
Tiwe's Avatar
Default Re: exhaust ....bigger...better? (Rob :190:)
ok then why dose Spoon and Mugen and many other brands make their cat-backs 2.38" (60.5mm) instead of making it 2.5"??
Old Dec 1, 2002 | 10:28 PM
Rob :190:'s Avatar
basically because they wanted to. Just because their systems arent 2.5 doesnt necessarily mean they're bad
Old Dec 1, 2002 | 10:43 PM
Type-Rare#1248's Avatar
you make spoon and mugen sound like god
Old Dec 2, 2002 | 01:27 AM
uNF$@#!'s Avatar
heh.
first off, reason being is they run the world around a metric system, just like the rest of the world. we're the only we-todd-did country to run with this impirical system crap.
Old Dec 2, 2002 | 04:48 AM
itr1244's Avatar
exhaust ....bigger...better??
No.
Old Dec 2, 2002 | 05:22 AM
Ex-ITR5874's Avatar
[QUOTE]Re: exhaust ....bigger...better?[QUOTE]
No.... This has nothing to do with bigger or smaller...
You`ll have to find the optimal dimension for your personal setup, means: Find the perfect mixture of waste-quantity and waste-velocity.... Just like you design your intake.
[Modified by ITR1858, 3:23 PM 12/2/2002]
Old Dec 2, 2002 | 08:12 AM
Default Re: exhaust ....bigger...better? (George Knighton)
You have English (US) which is the measurement to which we're accustomed in the United States.
You also have English (Imperial), which has largely fallen into disuse since the United Kingdom itself uses a mixture of English and metric measure. In the UK, someone might use litres to measure volume displacement, but the road signs are in miles per hour.
You might have noticed from reading owners manuals that Canadian gallons and quarts are a different size from US gallons and quarts. This is because at some point the US changed its English measurement system to be different from the rest of the English speaking world. I don't know why, and I'd appreciate knowing why, if anyone has that information.
Depending on <u>what</u> you are measuring, the US English system can also be called "SAE" for linear English measure.
No man, we use litres in Canada
Old Dec 2, 2002 | 12:29 PM
RICHJ's Avatar
SO true (see my sig metric and imperial in there, LOL). And we measure our exhaust piping in inches.
[Modified by RICHJ, 9:30 PM 12/2/2002]
integra3586
Nov 5, 2008 07:50 PM
krazy
Aug 18, 2003 07:12 PM
Project X
Aug 18, 2002 09:50 PM
Wet Nudl
Oct 21, 2001 12:44 PM
Striker
Sep 18, 2001 03:53 AM
