reset ecu. tried the search
Old Dec 1, 2002 | 09:36 PM
LsPower's Avatar
Default reset ecu. tried the search
Ok I thought I knew how to reset my ecu but one my friends is telling me that it is the wrong way. Will someone please tell me the correct way to reset the ecu.
Old Dec 1, 2002 | 09:38 PM
97hb's Avatar
Default Re: reset ecu. tried the search (LsPower)
Pull the negitive off the battery for 10-15min. Or pull the fuse for the ecu for 10-15min. While doing this you might want to flash your highbeams for brake pedal to make sure all the charge is out of the system.
Old Dec 1, 2002 | 09:51 PM
Nameless RB26's Avatar
There are lots of ways.
Unplug the ecu from the harness.
Remove the negative cable from battery.
Remove some fuse -don't know which-
Or cut the engine harness, and re-wire it back together when you're ready. I don't recommend that..
It doesn't matter how you reset it..
Old Dec 2, 2002 | 12:43 AM
NuclearB18B's Avatar
Default Re: reset ecu. tried the search (Nameless)
haynes manual says remove the backup fuse from the engine compartment fuse box for like 10 seconds
Old Dec 2, 2002 | 02:20 AM
bocian's Avatar
Default Re: reset ecu. tried the search (ha illuminato un)
remove the negative battery cable.
97hp had a good point, deplete the system of any charge, good idea
never thought of that
Old Dec 2, 2002 | 07:58 AM
LsPower's Avatar
Default Re: reset ecu. tried the search (bocian)
thanks everyone. I proved my friend wrong
crxsi814
Jan 18, 2011 06:25 PM
9civic8
Apr 2, 2004 08:51 AM
RIX982DRLS
May 13, 2003 12:23 PM
SoNNyBoY9o9
Nov 4, 2002 09:23 AM
jermothedrunk
May 29, 2002 10:04 PM
