B18a head on a B20b or B20z block???
Old Dec 1, 2002 | 08:38 PM
DoctorGSR's Avatar
Default B18a head on a B20b or B20z block???
i spun a bearing on my engine and instead of gettin another LS block, im thinking about getting a CRV block. basically my question is, will this work, and how much more work is involved than putting a b18a head on a b18a block? will this be easy for a mechanic to do? also do u guys reccomend any sites that sell blocks with a warranty? any information anyone can give will be greatly appreciated. TIA
Old Dec 2, 2002 | 05:11 AM
DevinW's Avatar
Default Re: B18a head on a B20b or B20z block??? (QuikLS)
Replacing a broken B18B block with a B20B/Z block is a good idea, and you should have no problems doing the changeover. I reccommend finding a Z block since it has the higher compression and will give you more HP than the B18A block. Both blocks will give you better torque though.
I got a B20Z longblock at a salvage yard and it came with a 6 month warranty. Most places that you buy engines from will have some sort of warranty.
Good luck!
Old Dec 2, 2002 | 07:42 AM
migs's Avatar
Default Re: B18a head on a B20b or B20z block??? (DevinW)
USDM B20Z# = JDM B20B
Both have 9.6:1 compression.
Edit: by the way, ITR tranny on B20 blocks OWN.
[Modified by Migs, 10:42 AM 12/2/2002]
Old Dec 2, 2002 | 09:33 AM
DoctorGSR's Avatar
Default Re: B18a head on a B20b or B20z block??? (Migs)
i just thought of a problem: my car has a cable tranny. did either of these have a cable tranny or were they both hydraulic? what can be done about this?
Old Dec 2, 2002 | 01:09 PM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
keep your old trans b20,b18a, b18c, b16a. all bolt to your cable ls trans
1strdko
Sep 8, 2003 04:12 PM
Henry HA
Mar 9, 2003 07:41 PM
2dark2bslow
Sep 28, 2002 05:11 AM
b20eg6
Apr 24, 2002 06:37 AM
