how much power can a stock clutch hold??
Old Dec 1, 2002 | 01:18 PM
donnie B's Avatar
Default how much power can a stock clutch hold??
i have a stock type r clutch and pp in my h/b and i am putting out 180hp and 200 ft/lbs and im upping the boost from 5.5 to 9 psi and i was hoping to lay down around 200+ hp and 225+ ft/lbs and i was wondering how the clutch is gona hold up fo mee
peas
donnie
Old Dec 1, 2002 | 03:52 PM
Misfit's Avatar
Default Re: how much power can a stock clutch hold?? (donniEK)
You are doomed. swap it out soon. I have heard too many horror stories about stock clutches slipping. you may want to look into a change.
You will be fine for a little bit. but i would play it safe if you have the money.
Old Dec 1, 2002 | 04:10 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: how much power can a stock clutch hold?? (MISFIT)
Doomed, it's gonna slip like a mother under any mild boost conditions and higher.
Old Dec 1, 2002 | 04:24 PM
donnie B's Avatar
Default Re: how much power can a stock clutch hold?? (Rguy)
ive been driving on it for around 5000 miles with boost i havent noticed any slipping at all.. but i run only like 5.5-6 psi now... oh well car is going away for the winter...
Old Dec 1, 2002 | 05:18 PM
Andrew 825SM's Avatar
i have a gsr turbo running 10 psi daily and my clutch has been holding for almost a year now.
Old Dec 1, 2002 | 08:49 PM
1.8TypeR's Avatar
Default Re: how much power can a stock clutch hold?? (Airtracks)
my clutchnet stage 2 gave out in just over a year(12kmiles). not even hard driving. this is @6psi. so im sure ur stock clutch wont last too long.
acuralovar
Dec 25, 2009 10:13 PM
Boosted_93_Si
Oct 12, 2005 07:32 PM
Btothe3rdDegree
Oct 3, 2004 12:54 AM
Nextelbuddy
Aug 29, 2003 10:29 AM
sIcWiTiT
Apr 22, 2003 10:10 PM
