Ball Joint quickie
Old Dec 1, 2002 | 10:56 AM
Armed Ferret's Avatar
Default Ball Joint quickie
How does one tell when ball joints (as in upper and lower BJ's on the knuckle) have gone to the great ball joint place in the sky? thankyaverymuch
Old Dec 1, 2002 | 11:48 AM
liquid51's Avatar
Default Re: Ball Joint quickie (zoomintegra)
If they're really sqeaky. Look at the boot, if it's torn anywhere then the grease is most likely all gone. I let mine get so bad before I changed them that the boot was almost gone, and the ball and socket were rusty.
Old Dec 1, 2002 | 06:50 PM
B18aTegra's Avatar
I would like to know this as well. do they clunck at all or just squeak?
Old Dec 1, 2002 | 07:26 PM
D-Man's Avatar
jack it up and tug and push on the bottom and top of the tire to see if there is any play in them
Old Dec 1, 2002 | 08:13 PM
Default Re: Ball Joint quickie (D-Man)
i thought that was for wheel bearings, not ball joints......
oh and josh, i wonder why you might be so interested in this.
Old Dec 1, 2002 | 08:21 PM
D-Man's Avatar
yup for both
Old Dec 1, 2002 | 11:13 PM
kinesistech's Avatar
Push on the component that the ball joint is mounted on, it it has any play you should feel it. If you find play, replace the joint.
Old Dec 2, 2002 | 04:13 AM
itrSteez's Avatar
Default Re: Ball Joint quickie (kinesistech)
if your dust seal is gone then get it the **** outta there, grease will soon enough be replaced with salt/sand, then it's fucked
Old Dec 6, 2002 | 11:33 AM
joeseph's Avatar
Default Re: Ball Joint quickie (prawjEKt Cx)
How difficult is it to replace a ball joint yourself?
[Modified by joseph h, 2:38 PM 12/6/2002]
Old Dec 6, 2002 | 02:14 PM
Patron's Avatar
let us be accurate on whether we are giving advice on the ball joints or the CV joints, totally different.
Old Dec 6, 2002 | 05:07 PM
ridous's Avatar
Default Re: Ball Joint quickie (joseph h)
upper ball joint no problem, bottom ball joint if you have a hydrolic press, the proper tools and a lot of patients you get it out, it took me 2 days and 4 big craftsman vises (think god for the warrenty) and i did it
Old Dec 7, 2002 | 12:33 PM
joeseph's Avatar
Default Re: Ball Joint quickie (ridous)
sorry I should of clarified, to replace my upper ball joint I'm just replacing the entire upper A-arm.
I was wondering about the lower one. Form what you say it sounds like a royal pain in the ***, I think I'll just removed my steering knuckle and take it somewhere to get a new ball joint.
thanks
Old Dec 7, 2002 | 01:14 PM
jdmillusion's Avatar
Default Re: Ball Joint quickie (ptran13)
and i was lost there for a minute. drivetrain or suspension??? hhhmmm
retriever99
Jan 8, 2020 07:12 AM
eurochoi
18
Aug 2, 2012 09:32 AM
rdean
Honda Civic (2001 - 2005)
Mar 15, 2011 02:07 AM
'00DC2
Suspension & Brakes
Dec 2, 2009 05:24 PM
Keebler
Jul 13, 2004 04:45 AM
